Old 07-24-2005, 10:51 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need some water pump help 454 B.B
What are you guys running for water pumps are you running a short pump or the long pump I have the long pump on now but an not sure if it will clear everything once I get it all back together... Any feedback would be great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-24-2005, 11:29 AM   #2
COBRO
Active Member
The 454 in my 72 has a short pump on it -Im using all the stock brackets and pullies that came with the 402 that came in the truck. I would guess you need to figure what pump your brackets are set for so the belts will line up. HTH::::CB
COBRO is offline   Reply With Quote
Old 07-24-2005, 11:31 AM   #3
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
I'm running the long water pump its close but will work with a few mods to the fan housing. In case you don't know brackets and pulley's for short and long water pumps don't enter change.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 07-24-2005, 12:16 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
I have the long water pump and bracket's that came with the 454 and am planning on running a electric fan set-up and am gonna order some new bracket's and a nice set of pulley's but wanted to make sure it would all fit before I started spending money on part's .. Thanks guys for your helpful info.....
MEMBER #6377
Project "7DEUCE"
Old 07-24-2005, 01:37 PM   #5
COBRO
Active Member
Thumbs up
Yes if your going with an electric fan then you should have plently of room even with the long pump - I have looked at the GM performance serpentine belt conversion for my truck which uses a long pump and even keeping the flex fan I figured I have enough room. Am thinking that the difference between the long and short pump is like 1-1/2 " HTH:::::CB
Old 07-25-2005, 09:10 AM   #6
dwaite72lnghrn
With the Serpentine setup long pump reverse flow, you will have about 2 3/4" between the bolts on the water pump pulley and the radiator. To run a 16" flex fan you need a 1" spacer, I DON'T think a clutch type fan will fit with a serpentine setup.
I could not fit electric fans between the rad and serp. Even in front of the rad it was tight with the airconditioning condenser. I could only fit 12" fans up front. The 1" spacer for the flex fan was needed to clear the belt and pulley. Yo go with a bigger 17" or 18" flex you would have to go to 2" spacer and have a bugger of a time trying to bolt it on the water pump.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 07-25-2005, 10:02 AM   #7
Purs
Got Big Block?
Purs's Avatar
i've got about 3" of space between my fans and pulleys. more than enough. the brackets are off an 86 1 ton pickup.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Thread Tools
Display Modes
