Old 07-27-2005, 12:53 PM   #1
vtblazer
vtblazer's Avatar
Adding Power Brake Booster Questions
My 71 has manual brakes.
Can I just remove a booster and bracket from another truck and install?
Could it be that easy?
I'm thinking maybe need to change the rod from the pedal...?
Use the same master or install the one that's currenty on the booster?
I'd rather not need to 'open' the system but thought I'd check to find out if there's some answer out there.
Thanks.
vtblazer is offline   Reply With Quote
Old 07-27-2005, 01:06 PM   #2
farside847
farside847's Avatar
Yup, it is that easy. (hey, if I did it - it must be)
You will need the power rod, the manual one is too long. You can use the same MC.
Here is my install:
http://67-72chevytrucks.com/vboard/s....php3?t=163387
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-27-2005, 01:07 PM   #3
panhandler62
Java Mechanic
panhandler62's Avatar
There is an faq on that.. basicaly -- you can use the same master, you'll need a new rod (not the same length) and everything basicaly bolts up .. you need to tap the vacume from the manifold, of course.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-27-2005, 01:08 PM   #4
matthufham
also see this
http://67-72chevytrucks.com/vboard/s....php3?t=165344
matthufham is offline   Reply With Quote
Old 07-27-2005, 01:48 PM   #5
phlegm
Still Green but learning
phlegm's Avatar
Great info guys, I had the same question a while back. If I get a new booster from car quest it does not have the rod with it, where can I get one?
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 07-27-2005, 04:51 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Here's three pictures that I took when I converted my truck to power brakes.
You need the linkage and brackets that go between the booster and firewall. The rod that comes out of the brake booster is not the rod that connects to the brake pedal. There is an intermediate linkage between the booster and pedal.
Study the pictures and you'll see what I mean.
Old 07-27-2005, 05:57 PM   #7
vtblazer
vtblazer's Avatar
Great info, thanks guys.
Next time up to the shop, I'll get-r-done.
Thanks again.
Old 07-27-2005, 06:25 PM   #8
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Can I put a booster on my 4-wheel drum braked truck?
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 07-27-2005, 06:29 PM   #9
tom1000
Sorry to tell you this
Yes it's that simple.
You have to bend the break lines a little and add the vaccume hose but it's really easy.
tom1000 is offline   Reply With Quote
Old 07-27-2005, 10:25 PM   #10
krue
Designated A-hole!
krue's Avatar
Yeah, I did, good low buck improvement until I can get the disc brakes done.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-31-2005, 08:12 AM   #11
vtblazer
vtblazer's Avatar
Huge difference to drive now.
I pulled a booster set up from a 71 2wd 3/4 ton truck and swapped it over to mine, conversion was easy and straight forward.
Used the original master, no brake bleeding needed.
Since I didn't even clean it up, it looks like it's always been there.
Old 07-31-2005, 09:40 AM   #12
krue
Designated A-hole!
krue's Avatar
Now you're not getting that workout every time you stop.
www.daveramsey.com
Thread Tools
Display Modes
