Old 07-28-2005, 09:16 PM   #1
matthufham
removing interior pieces?
i ruined my cig. lighter removing it, and figured i was on a roll when i couldn't get the ignition out. the manual says insert a piece of wire into the hole and make sure the key is on acc... ok step one complete. then rotate counterclockwise... it didn't move and i was waiting for it to move so "the lock cylinder will come out." well like i said the key wouldn't move and i didn't want to ruin my ignition, so how do i get it out?
matthufham is offline   Reply With Quote
Old 07-28-2005, 10:01 PM   #2
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
You are right there , some times a little WD40 helps , just put a paper clip in the small hole and turn the key counterclockwise ( in the direction of Ass) or further ,and pull it out .
Good luck .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 07-28-2005, 10:04 PM   #3
knsmodels
I make Models
knsmodels's Avatar
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 07-28-2005, 10:06 PM   #4
matthufham
hmm, i'll try that in the morning. anybody else?
Old 07-28-2005, 11:01 PM   #5
pjmoreland
pjmoreland's Avatar
Wiggle it like crazy while you're pulling on it.
pjmoreland is online now   Reply With Quote
Old 07-29-2005, 02:24 AM   #6
knsmodels
I make Models
knsmodels's Avatar
Hey now lets keep it clean....
Old 07-29-2005, 09:48 AM   #7
matthufham
yea i've done plenty of that, bent the key too. had to bend it back straight.
Old 07-29-2005, 10:40 AM   #8
farside847
farside847's Avatar
"wiggle the handle"... words to live by.
Mine had to be turned pretty far left, well past ACC
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-29-2005, 01:34 PM   #9
mrein3
mrein3's Avatar
When I did mine the first time it didn't just fall out as advertised. I had the wire in the hole, key turned, nothing. I messed around and messed around and all of a sudden it just fell out.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-29-2005, 01:42 PM   #10
matthufham
well mine still wont come out. i've shaken, oiled, used penetrating lube, and put the strongest small wire i could find, (.30 welding wire) and i found a nail that fit in there too, and i just can't get the key to turn counter clockwise.
Old 07-29-2005, 01:50 PM   #11
Bill72BB
Bill72BB's Avatar
Matt; They can be boogers the first time,Try 2 different technique's
First turn the key counterclockwise then place the wire ,in the hole and try to turn further .
Next, place wire in hole and turn counterclockwise .
Last .BFH
BILL
Member DUF Club
Old 07-29-2005, 01:59 PM   #12
matthufham
done that, i guess i just have to do it til it works.
let us pray.
Old 07-29-2005, 04:34 PM   #13
Bill72BB
Bill72BB's Avatar
Let it sit for a day , your probably pissed . Tomorrow it will probably fall out in your hand .
BILL
Member DUF Club
Old 07-29-2005, 04:56 PM   #14
Mudder
Mudder's Avatar
Praying does help!!!!!!!!!! Holding your mouth in the right position helps also.
Mudder is offline   Reply With Quote
Old 07-29-2005, 05:25 PM   #15
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Calling it the right name helps too...
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 07-29-2005, 05:57 PM   #16
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
i thought to take it out you just spin the round chrome thing the ignition is in. mine fell out one day going down the road cause that chrome peice worked its way off the threads
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 07-29-2005, 08:07 PM   #17
matthufham
i spun that ring as far as it would go, but nothing would come off.
Old 07-30-2005, 12:48 AM   #18
Solver
Solver's Avatar
I find that if you are not lined up with the pin when you push in the paper clip in you wont get the cylinder to go past. Just in case you don't have one to go by as a guide here is a pic (somewhat fuzzy) of the ignition switch and the pin you are trying to push in on. It is spring loaded and that is what you are trying to get the cylinder by. As a reference I believe that the flat spot on the casing is the bottom of the ign switch when installed
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 07-30-2005, 01:52 AM   #19
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Sometimes they have never been out of the switch,and are a PITA to get out.I had to use some of these bad boys to pull the tumblers out once I got it turned back
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 07-30-2005, 10:20 AM   #20
matthufham
thanks solver now i know why i'm putting the stupid pin in there.
Old 07-30-2005, 07:35 PM   #21
purple gas
some years don't have an acc position and I think then you trun it to the run position. I've taken several out and even when you've done it before it can drive you crazy. Done freak out & keep trying ( easier said than done). After the pin is pushed in you still have to turn the bezel part to get it to come off I think. Sure as shootin it will eventually just fall apart and you'll never really know how you did it. That's the part that REALLY drives me crazy.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Thread Tools
Display Modes
