Old 07-29-2005, 04:37 PM   #1
motocrosschump
Oh Crap!!!
I bought a Flywheel for my 95 350 Engine that was going to be mated to the factory 3 speed (69) and the flywheel bolts don't line up to the clutch, do I need to order for a flywheel for a 69 350 or a different one for a 95?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 07-29-2005, 06:09 PM   #2
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
I believe you either need to re-drill the flywheel to match the clutch, or get a new clutch that matches the flywheel. I had the same problem and just had to get a new clutch. However, being that there is quite an age difference between the two, make sure hte clutch also fits on the tranny.
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 07-29-2005, 06:13 PM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
It might not jive with your starter either..You should take it back and get the right one..
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-29-2005, 11:05 PM   #4
motocrosschump
Is the crank the same on the 95 and a 69 on the 350?
Old 07-29-2005, 11:19 PM   #5
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Wait a second... Isn;t there a whole internally ballanced externally balanced thing? Cableguy steered me right when I was going through harmonic balancer issues...
chickenwing is offline   Reply With Quote
Old 07-29-2005, 11:51 PM   #6
motocrosschump
I just need to know what to get
Old 07-30-2005, 12:26 AM   #7
69 longhorn
If you are running the stock 68-72 bell. you need a 168 tooth flywheel , to fit the 95 smallblock. GM # 10105832....14" dia,86 up sb, 11 or 11.85" dia clutch. Thats right out of the 99 parts book L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 07-30-2005, 12:32 AM   #8
chickenwing
Looked up a 68 c-20 for clutch diameter at Autozone.com shows an 11" and a 12".
Old 07-30-2005, 12:36 AM   #9
dtlilly
dtlilly's Avatar
Don't know what size clitch you need, since my 72 C-30 and 465 manual tranny took an 11"
dtlilly is offline   Reply With Quote
Old 07-30-2005, 12:42 AM   #10
chickenwing
Looked up a 68 flywheel and it shows 168 teeth. So yor starter should be good. The flywheels list a 10.5" clutch and another flywheel for both a 11" and 12" clutch.
Oh and 69 longhorn is da man!!!
Thread Tools
Display Modes
