Old 08-04-2005, 11:13 PM   #1
KEH
Better late than never
KEH's Avatar
What's the story on a T-5 tranny?
I am looking to replace my Saginaw and someone mentioned the t5 as a possibility. But someone else said they are not strong enough to go behind my 350. Anyone have any input? Thanks
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 08-04-2005, 11:26 PM   #2
walker
walker's Avatar
A Borg Warner T-5 tranny is commonly found behind v-6 engines on S-10s and astro vans. They are reasonably strong but not great behind a 350. The T-5 you would want would be a World Class tranny that they put in mustangs. They have better gearing and a different bearing set up. The good thing about T-5's is that there are a lot of bellhousings available to mate up to near anything.
I am not a tranny expert, these are only things I found out while trying to figure out what to put behind my flathead V-8 80 in my other hotrod.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-04-2005, 11:41 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the strongest one, the world class T5 is only made to hold 305 ft lbs of torque. Add a heavy truck, and you are flirting with trouble if you drive it hard. (hot rodding or towing)
If you just pedal it around, then it'll be OK.Remembger, GM never bolted one to a 350, the ones in the camaros and mustangs were falling apart bolted to a 5 liter.
Old 08-05-2005, 12:06 AM   #4
modifiedGMC
The world class t-5 also was in V8 camaros. The newer t-5's after 91 or 92 were stronger. There is also two different bolt patterns where they bolt to the bell housing. some of the v6 t-5's wont bolt to the v8 bell housing. The t-5 bell housing has the tranny bolt holes tilted at an angle while a regular 3 or 4 speed bellhousing has the bolt holes straight. but they will bolt to either bellhousing. World class t-5's have needle bearings under the gears, fiber syncronizers, and tapered roller bearings. Non-world class t-5's have journals under the gears, brass syncronizers, and straight roller bearings. Here is a link that tell about the t-5's, there history and has a box to indentify them and what they came out of. http://www.5speeds.com/t5/
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 08-05-2005, 01:13 AM   #5
71Chevy4-speed
Speed Limit = Floorboard
71Chevy4-speed's Avatar
imagine driving at 50 mph and your rear tires lock!...not slamming on your brakes....but your tranny seizing....its quite a ride....
it happened im my buddys camaro 305 with a non-world class Borg Warner T-5...i do not like them and they dont hold up very well from my experience. if you are going to get one, buy a world class version, he got one for his and it works much better. A non-world class T-5 behind a 400 horse 350 in a 74 nova lasts about a month.
1971 C20 350, 4-speed - Sold.
1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project.
"Build for torque, horsepower will follow"
71Chevy4-speed is offline   Reply With Quote
Old 08-05-2005, 01:41 AM   #6
69 Short Fleet
Or you could go with a T-56
69 Short Fleet is offline   Reply With Quote
Old 08-05-2005, 10:20 AM   #7
1low1967
1low1967's Avatar
Im going to try to run an NV3500 out of a 89 GMC 2 wheel drive, Any reports on those??
1low1967 is offline   Reply With Quote
Old 08-05-2005, 11:52 AM   #8
CHEVYE
my gas saver
CHEVYE's Avatar
i think "huck" or one of the guys in KY has done this conversion. maybe they will chime in. if i were gonna go 5spd, i would try to go with the NV too.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 08-05-2005, 09:55 PM   #9
KEH
KEH's Avatar
Okay, the more I study this the less clear I am on what to do. Has anyone installed a 5 or 6 speed (with overdrive) behind a 350 and having good luck with it? It sounds as though the world class T5, a T56, or a NV3500 are options.
Old 08-06-2005, 12:36 AM   #10
jamal
jamal's Avatar
That would be awesome
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 08-06-2005, 04:01 PM   #11
dwaite72lnghrn
I think 69_longhorn put a 6 speed behind his 383 in a drop/chopped longhorn.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 08-06-2005, 09:04 PM   #12
69 Short Fleet
If I remember right I think NeonLarry has the T-56 speed also. I was looking into this a while ago and was reading a website where a fellow with a 67 Chevelle did this upgrade, he has a step by step article with lots of pics. I'll see if I can post his website for you later tonight. The shifter location was a bit of a pain (as its sits rearward quite a fair amount but if you take your time it can be done (of course you will have to shorten your driveshaft and I think modify or relocate the cross member (as well as some other stuff). Doug
Old 08-07-2005, 01:40 AM   #13
69 Short Fleet
Here you go
http://www.ls2.com/forums/printthread.php?threadid=1877
http://www.5speedtransmission.com/t56_early_gm.html
http://www.darklair.com/manual_monte.html
Hope these help. Doug
Thread Tools
Display Modes
