Tunes
I am trying to figure out how to install a clean stereo system,I have an uncut dash ,no interior yet and want to stay away from cutting doors or adding those kick panel speakers
SKINNY TIRES RULE!
One of the board members mounted their CD player in the console. This is what I plan to do as well. Sorry, I can't remember whos this is...
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
They are high-dollar, but www.tuffyproducts.com has security stereo consoles. I'll probably go this route if I can't get one of my buddies to fab up a custom one.
![]() Join Date: Apr 2000
i got mine in the console, and an am in the dash.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
I cut the dash in my truck, but you could do same install with a dual shaft knob radio or put in console etc. like others have done. I installed a 10" sub under passenger side of seat and separates in the doors. You cut the panel and a hole behind it, but a new door panel and all signs of speaker are gone!
you could even use one of the hidden or "stock lookalikes" still have cd playing capablities, just look stock fresh.
Lmc truck carrys them, but there only in the paper catalog, I'll type up what it says. -These state of the art stereos are made to fit your origanl dash opening without cutting or modifying. for stereo sound without having to add more speakers, hook them to a dual stereo speaker shown on page 80. All Necessary hardware and installation instructions are included with each sstereo. Stereos must be used with LH/RH speakers or a dual stereo speaker. Tuner Features: Am/Fm stereo cassette. PLL(phase lock loop) Electornic synthesizer tuner with manual or eletronic tuning. PLL is designed to capture and hold the signal, eliminating station drift. Local and long distance switch allows you to adjust the sensitivity of the tuner to accommondate the weakness of distant stationa nd the over loading of local stations. Sperate bass and treble controls, left and right balence control, 4 way fader allos you to adjust the volume from front to rear speakers indepently and to repostion the balence sound. auto scan gives 5 sec preview of every avaible station, seek changes to next station. Audio Features: RCA preouts allow amplifiers to be connected directly to the radio internally. 32 watts per channel. (4 channel) Cassette Features: Auto reverse automatically plays reverse siide of tape when you reach the end of the tape, FF, R, Tape and Stereo indicators. Additional Features: Power antenna lead, chrome radio face. Cassette Stereos with CD changer controller: get the only AM/FM Cassette CD changer controller built exclusively for classics. Enjoy Top-Of-the-Line sound with this 100 watt stereo and cd changer. Custom fitted to your dash and installs in the stock opening just like the original radio, contorl the 10 disk cd changer directly fromt he buttons on the face of your radio. Cd Changer Controller - buttons on radio will control all functions of the optional 10 disc cd changer. cd track disc/scan/repeat/random play, 30 station preset. 12 AM 18 FM The Stereo with the "bowtie" on the tape door is - #38-8540 The stereo with "GMC" on the tape door is - #38-8542 the the 10 disc changer it costs $300 Information was pulled from page 81 of "LMC Truck" 2005 Winter Edition. Hope i helped, figure these will look better, and be less likely to be stolen by the average joe who looks inside your truck and see's a old looking stereo. -Cameron took only 10 minutes, ![]()
1972 Dark blue, Cst, Highlander Last edited by ClassicStyle; 08-08-2005 at 04:35 PM. |
SKINNY TIRES RULE!
I have not heard good things about the sound quality of the stock lookalike systems in LMC. I believe they are custom auto sound (http://www.customautosound.com/). This is all hearsay, so do your own research.
hmm, well im glad you told me, i was going to look into that and a nice amp for my future system.
1972 Dark blue, Cst, Highlander |
I am curious to see a very classy sound system that will rock when the ladies are lookin
In the first pic Bouncytruck posted that's
a universal under dash cover for any stereos you want to install. It works great in the console. If you cant find one there is a shop here in FT.W.TX. that has them for about 20.00-25.00 bucks ![]()
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
Just need a couple more parts.
LMC stereo
Here is a pic of the LMC stereo that was mentioned earlier.
You get to keep your dash intact. It came with my blazer and sounds great with the crossfire amps the guy before me put in. Not sure what it will do on its own. The down side is you are very limited if you like to "play" with settings as you only have a bit of adjustment on the knobs on the arms.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
sweeet. one would think that once hooked to a good set of amps it'd sound awesome, but you never know. did you get the cd player one?
-Cameron
#13 |
SKINNY TIRES RULE!
I thought they were just CD changer controlers. I think you need to buy their changer to work with the head unit.
As far as the qualitity, I'm just restating what I have read on the board. Do a search on the board and see what you find.
#14 |
Merciless Butcher
Sound System
I built my sub box out of fiberglass and mounted two 10's in it. While the cab was stripped down prior to paint, mounting brackets were welded into the cab corners and panels were made to mount 6" Fosgate mids. Two four inch Fosgates were mounted under the dash in the original speaker location. Amps and an electronic crossover were mounted under the seat. I did cut the dash as I was'nt concerned with originality...System hits really hard and is crystal clear.
Your Bought And Sold....I Got Your Soul! |
#15 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Here is a pretty sweet set-up in a blazer..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#16 |
I have the custom autosound system in my 68. All of their stuff is rebadged kenwood, so not bad quality. Being that our vehicles are not the quietest, you really need a couple amps and some good speakers. However, mine doesn't sound bad with no amps and some good quality (polk audio) door speakers.
I wouldn't knock the quality but they are overpriced. Of course, they are also one of the few places that carries setups that don't require cutting the dash or a little creativity.
CPO U.S. Navy(Ret) 1972 GMC Jimmy 4x4 Custom 1972 GMC Jimmy 2x4 Custom |
#17 |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Does anyone know if you can use non-deluxe type knobs on those radio's from LMC and Chevy Duty?
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
#18 |
Pretty sure you can use any "old style" type knob on them. All the control posts are the same IIR. Just pull off and replace.
#19 |
Born To Lose Club
Thanks Clean71!
#20 |
Check out GMTrucks.org
I've seen a lot of ideas of where to put the head unit, but I'm interested (I think the original poster is too) in how you guys are mounting your speakers. What speakers are you running and where? I'm not too excited about cutting up my doors either.
#21 |
SKINNY TIRES RULE!
I just finished installing the head unit and a 6 disk changer in the console similar to the picture I posted above. I'm very pleased with how the install turned out.
For now, I'm running just some 6x9's in some of the cheap-o, carpet covered boxes. Eventually, I'd like to build some custom boxes along the side that will look like a continuation of my aux gas tanks. Maybe some kick panel speakers too. I've been thinking about a couple of tweeters in the factory dash location so they are hidden, but I'm not sure how that would sound. I'd like to hide as much as possible and not cut anything.
#22 |
New Guy
Speakers, etc
In my old 76 K5 i built a kick-ass center console that housed my in-dash and my amp... the truck wasn't built stock so i didnt have to worry about that too much, but it looked cool. as far as the speakers, I had a 64 Corvair once (dont laugh) that i built 'wedges' that were tucked under the dash kinda, you couldnt see them unless you bent down and were looking for them...
as far as the back goes... ive seen it before where they'd build a box to fit around the wheel well, if you do it right, it would look pretty cool. my dumbass put a huge bandpass box in back with 2- 15's and kept on blowing out my back window... i wouldnt suggest that!!! wish i would have taken pictures of it... but i do have some from a council i built for my old 80 chevy pickup... ill try and round those up and post them for ya! Hope my rambling helped a little bit!
~Guttdogg |
Thread Tools | |
Display Modes | |
