Old 08-09-2005, 03:32 PM   #1
canadian trucker
A day should have 30 hours.
Exclamation Air Bag Help
I am runing single convulted bags on the front of my truck. their max height is 9'' so too short for a replacement of a regular coil. so i am shimming them with 1.5'' blocks of alu. the height is perfect but in order to keep the shimms from moving i welded in a plate on the bottom c-arm with a hole in the center (shims also have a hole in the center) and ran a bolt throught the plate, shims and into the bottom airbag mounting hole now my bag has a fold in the middle will this be a problem or should i go with double convaulted bags. any info would be great
p.s. how do u get pic's into here it does not work for me and i have a bunch.
thankx
canadian trucker is offline   Reply With Quote
Old 08-09-2005, 06:47 PM   #2
fastbagged68
fastbagged68's Avatar
Single convulated bags.....meaning sleeve bags are not for mounting in control arms. You should switch to a double convulated bag.
fastbagged68 is offline   Reply With Quote
Old 08-09-2005, 06:49 PM   #3
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
are you using a firestone rs9000? if so the rating is probably to low you will be better off going with the heaver duty bag like a 2500 i hope this helps
gostranger is offline   Reply With Quote
Old 08-09-2005, 07:34 PM   #4
KdawgS10
keller
KdawgS10's Avatar
Single convulated bags dosent really mean sleaves. they do really make Single convulated bags. its just a regular 1 bellow bag. posable to get at heavy trucks shops evrywear.
but I would still sugest gitting your self a set of 2600# for the front. as thier pretty mutch made for and proven to work on a control arm setup.
83 1ton 4door dually, 350/700r4
99 S10 2.2/5speed bagged. traded for the dually
91 S10, 2.5/5speed juiced
87 3/4 4x4, 350/4speed
89 S10 long bed , 2.8/5speed
65 chevy short bed stepside, 327/3speed
97 neon acr, 2.0 dohc 5speed DD
KdawgS10 is offline   Reply With Quote
Old 08-10-2005, 10:08 AM   #5
Izzy
Trucker.
Izzy's Avatar
I agree.
Izzy is offline   Reply With Quote
Old 08-10-2005, 12:10 PM   #6
1low1967
1low1967's Avatar
If we could get a pic up that would be great, but i personally would go with a double bellow, 2600 or equal to it.
1low1967 is offline   Reply With Quote
Old 08-10-2005, 03:52 PM   #7
canadian trucker
sure just how can i get them in here
Old 08-10-2005, 03:56 PM   #8
Izzy
Trucker.
Izzy's Avatar
[img]http://www.*****************/main/images/full_chevy_frontbags.jpg[/img]
$59.99
Old 08-11-2005, 08:00 AM   #9
1low1967
1low1967's Avatar
I have the brackets from suicidedoors and their great.
Old 08-11-2005, 12:36 PM   #10
KdawgS10
keller
KdawgS10's Avatar
Email them to me I gess. I will host and post them for a while to help diagnose your problem.
Kmccowen@sbcglobal.net
Thread Tools
Display Modes
