Old 08-12-2005, 02:19 AM   #1
70short
instrument cluster problems
I am putting my interior back together (from paint) Cluster is in, here are my symptons.
When I pull the headlight switch out one notch.
red high beam light comes on.
both (LH & RH) turn signal arrows come on half intensity.
fuel gage dropped from 1/4 tank to the empty mark.
When I pull the head light switch completly out (headlights on).
red high beam light goes out.
both turn signal arrows come on full intensity (much brighter).
the fuel gage drives even farther below the empty mark.
In both instances when I turn my turn signals to either left or right the arrows do flash however they stay on. Everthing other than my cluster seem to operate normally. I have tried reseating my plug to the cluster, looking for an open or short (none found). Checking the wiring at the headlight switch (no problems found) HELP PLEASE.
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 08-12-2005, 04:45 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
bad ground
Old 08-12-2005, 06:34 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I agree, bad ground. Run a wire from the metal part of the rear cluster to the metal dash/firewall area.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-12-2005, 07:24 AM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
Check to make sure all of the panel lights are in securly.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 08-12-2005, 09:52 AM   #5
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
The very same thing happened on my truck. It was one of the small ground srews on the back of the panel.
I agree with All above BAD GROUND
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-12-2005, 05:36 PM   #6
70short
Thank You
Thank you very much everyone that replied. I grounded the cluster case and everything works great! Once again THANK YOU VERY MUCH!!!!!!!!!!!!
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 08-12-2005, 08:44 PM   #7
silvertonguedevil
silvertonguedevil's Avatar
Hey! I've got the same thing going on. I will try this also. This place rocks!!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Thread Tools
Display Modes
