08-18-2005, 05:56 PM | #1 |
Engine Stand Capacity?!?!
Hi Everyone,
I have two questions: I am about to pull my SBC out of my '72 and need to buy an engine stand. Would a 750# capacity stand be sufficient for a complete/turnkey 350 small block (alternator, waterpump,flywheel, etc all attached)? I am also wondering if there is any other types of seals or any other maintainance type work I should do while the engine is out. I plan of replacing the oil pan + seal, timing cover chain and seals water pump + seals, rear main, and every other external seal i can imagine. I also am going to take a look at the clutch and flywheel and repair as needed. Thanks again for all the help, take care. - Jerry |
08-18-2005, 06:23 PM | #2 |
my gas saver
750lb. stand should be fine.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
08-18-2005, 06:27 PM | #3 |
The LuvShack Garage
This is the rule of thumb I was always givin, no idea if it is correct,
but it does sound good, 3 wheel eng. stand = SBC, 4 wheel = BBC.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-18-2005, 06:37 PM | #4 |
though the 750lb stand is rated high enough to hold the engine. the 1000lb stand is a lot more stable and for the price difference its not worth trying to save a few bucks.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
08-18-2005, 06:58 PM | #5 | |
my gas saver
08-18-2005, 09:48 PM | #6 |
IMO, they ratings they have on those stands are "Under-rated" BIG TIME! We have a 1250 or 1000 lbs'er I can't remember which, but we bolted my 900 lbs Cummins on it with alot of parts off of it and you could watch the stand bending..................I held the engine up with the chain hoist in our shop while it was on the stand to prevent it from diving on the floor at any moment.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
08-18-2005, 09:58 PM | #7 |
user # 2756
You mean over-rate i.e. 1000lb stand only good for say 600lbs? I'd say the difference would be the center of gravity is further out on a big straight 6. I like my 4 wheel engine stand.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
08-18-2005, 10:24 PM | #8 |
Questionable
To give you an idea, my entire LS1 and T56 from length to tail weighed 780#'s on the scale at the freight company. And it's basically got everything on it including cats.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-18-2005, 10:30 PM | #9 |
its all about the +6 inches
I agree on going overboard. I got a cheap POS stand at the parts store a few years ago, and it is frightening to watch. Now, granted, i have kept big blocks on it for months at a time....but still, it is MUCH more comeforting to have it stable and not bouncing the engine up and down.
08-19-2005, 12:22 AM | #10 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
08-19-2005, 10:29 AM | #11 |
my gas saver
i'm all bassackwards right now. i have my small block short block on a 1500 stand and my fully assembled big block on an acdelco 1000 stand. lets just say the big block is sagging quite far right now. here's a pick, you can see it in the background. i'm gonna switch them around tomorrow. http://www.67-72chevytrucks.com/vboa....php3?t=169262
08-20-2005, 02:41 PM | #12 |
Watch out for your cornhole !
No matter what, get a 4 wheel model. The 3 wheelers will try to tip over when rolling them around the shop with a heavy engine on it. 4 wheels will stop all of that.
Spend the money, you're going to be using it for the rest of your life. Get a good one.
08-20-2005, 02:50 PM | #13 | |
08-20-2005, 05:46 PM | #14 |
buy the heavyest one youi can find // the cheapo swapmeet ones that claim 750lbs even the 1000lbers scare me -- won't work with them without a chain from the engine lift attached for backup
08-20-2005, 10:33 PM | #15 | |
Questionable
08-21-2005, 07:56 AM | #16 |
woodman13
Beat the horse, buy a 1250, worth the money 10 years from now.
Woodman13 2007 Dodge Ram 3500 5.9 rolling coal! 1994 Caprice 9C1 88K miles, LT-1, dropped/shaved 1967 C-30 350 4 sp dually 1971 C10 SWB BBC, auto; good driver |
Thread Tools | |
Display Modes | |
