Old 08-18-2005, 07:22 PM   #1
Blue4x4
Blue4x4's Avatar
Question Looking for crossover steering advise...
I am interested in do the crossover steering set up. PONT, you got really interested in it. Can someone post some pic's and the required parts for the conversion? And will I have to get a new stearing box? This conversion will be going on my 69 4X4 with a 4 inch suspension lift.
Blue4x4 is offline   Reply With Quote
Old 08-18-2005, 08:04 PM   #2
drink2mny
drink2mny's Avatar
you will need a flat top steering knuckle for the passenger side. it will need to be machined flat if it isn't perfect and it will need to be drilled and tapped.
you will need a steering arm for that same knuckle.
youy need a 2wd steering box. not one from a van(different setup). A dropped pitman arm. a crossover bar drilled and tapped to accept tie rod ends or other type joint..
http://www.blackbirdscustomtrucks.com/index12.html
Support The Board
drink2mny is offline   Reply With Quote
Thread Tools
Display Modes
