08-27-2005, 10:15 PM | #1 |
HELP!! need new engine
Hi Everyone,
I pulled my engine this weekend to replace all the seals, drop in a new clutch, and install a deep sump oil pan. As i tore the pan off, I noticed the bottom end of the motor is in HORRIBLE condition. The main bearings at the front of the motor had spun and created a HUGE gouge in the crank. Needless to say, the bearings are destroyed and the tolerences on the bottom end of toast. To make a long story short, i need a new motor. I am trying to find the best route here. I just need a decent SB 350. Are the GM crate motors any good? I have found a 290 HP GM 4 bolt or $1600, I sure some one here can direct me to a great source for this motor. What are my options price wise. I would like to keep it around this price range or less. Please let me know what you think, thanks again for all the help. Take care. - Jerry |
08-27-2005, 10:24 PM | #2 |
Personaly I wouldnt worry about being a 4 bolt. I have a drag car, not going to mention is maker, and it pushes over 1k hp when spraying. I used arp's strongest main studs and my engine holds up. I don't care what anyone says, when you have a BB runnning 14:1 compression, and spining to 7500 a 2 bolt is strong enough. In adition a camaro z28 with an lt1 pushing 300hp only had 2 bolt from the factory, but the big brother corvette did have 4 bolt. I would rather have the machine shop build my engine for its intended purpose but thats me.
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto. |
08-27-2005, 10:53 PM | #3 |
I wouldnt mess with that 290 hp crate, she has waaaay toooo much cam for the package. the 260 hp version is a better deal, & better warranty.....hell you can UP the cam later, < pick one that works L
http://community.webshots.com/user/hotrodhorn |
08-28-2005, 01:04 AM | #4 | |
Msgt USAF Ret
Why geta new engine
I bought a s-10 with a broken crank and put in a new one with bearings for $200 and drove it for 30,000 miles and sold it for what I paid for it. Now if you have a lot more damage than you said then that's different.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thread Tools | |
Display Modes | |
