Old 08-28-2005, 09:17 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Longhorn Rearend Eaton or GM...I need a real gasket!!!!!
Looks like an Eaton but I can't find it in my Chassis rebuild manual and the restoration manual is no help. 4.57 ratio however 7/32. I went to NAPA to get a new gasket and all they had was a very thin piece of paper that fit...said Dana on the package!!!!!! This does not look like a Dana casting or cover (round)! This thing had a cork gasket on it but I can't seem to find a replacement cork gasket. Thought I would ID the rearend first.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-28-2005, 10:30 PM   #2
Americanrider
Yea, it's a Eaton... clean it good & just use Blue RTV.
Americanrider is offline   Reply With Quote
Old 08-28-2005, 10:35 PM   #3
stllookn
stllookn's Avatar
Boone, Thanks. I am trying to do the 100 pt resto on this one so I think I am going to have to make a cork gasket. I hate being this picky! The good news is that it looks great and tight inside...WHOOO HOOOO!
Old 08-28-2005, 10:35 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just use sealant. I like The Right Stuff. Expensive, but it works. (and the OEM's all aprove it too)
Old 08-28-2005, 10:56 PM   #5
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Try Randy's Ring and Pinion. Use their 800 # ext. 5552 Tell Opie I told you to call. He is real good to work with.
oldiron is offline   Reply With Quote
Old 08-28-2005, 11:48 PM   #6
stllookn
stllookn's Avatar
Thanks guys...good suggestions. I will follow up. I was hoping to button it up today but it is raining for the first time in months so I guess we work in the garage tonight.
Old 08-29-2005, 12:01 AM   #7
Longhorn Man
it's raining in washington??? no way!
Old 08-29-2005, 02:54 AM   #8
4x4Poet
I recently bought a thick, round, paper gasket from NAPA for my '72 K20 pickup's Eaton rear cover. Still in the package. I could pull the part number tomorrow, if needed.
BTW, NAPA also sells the paper gasket that goes between the Eaton's third member and its axle housing. That, also round, gasket is thin paper– probably to keep the side gears properly aligned with the centerline of the inserted axles once the third member is torqued down.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-29-2005, 02:58 AM   #9
stllookn
stllookn's Avatar
The one the guy tried to sell me...and I refused to buy was that thin paper gasket! What a joke...I could have traced it on paper myself. I seriously thought it was the paper that was on the cork and someone just pulled the cork gasket out and left the paper inside.
Yes...I would like that part number if you have it.
Old 08-29-2005, 10:48 AM   #10
Chris H
72 C30 Trailer Queen
Chris H's Avatar
I have swapped a few Eaton 3rd members around, and I believe that these used a "paper" gasket from the factory.
I have used Permatex Ultra Black with good results, but it does not look absolutely original.
Do remember to use some kind of thread sealant on all the bolts, they go through the housing into the oil and will be quite messy in short order if not sealed. Dont ask me how I know this
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 08-29-2005, 11:10 AM   #11
stllookn
stllookn's Avatar
ChrisH, Good point. I pulled those bolts and watched the oil drain so I know what you mean. I will have to clean out the bottom of the housing before anything will seal those threads. The good thing is this baby is tight and looking good. I love when the PO takes care of the equipment. Some guys just never change the rear end oil!
Old 08-29-2005, 12:09 PM   #12
Dean
Dean's Avatar
I think GM did use the thin gasket. All I have ever seen when I pull them apart plus I ordered the gasket from GM and I got the thin one.
Dean is offline   Reply With Quote
Old 08-29-2005, 12:35 PM   #13
stllookn
stllookn's Avatar
Dean, Thanks...I guess I will have to use that one. This is why I love this board...eventually we can kick this thing around enough to make a good decision.
Old 08-29-2005, 12:47 PM   #14
D.PASSMORE
One of the First
D.PASSMORE's Avatar
gaskets
I have a few NOS ones. Cork. They are stashed away in a out of the way location. Take a week to drive over and lay hands on them. PM me and we can work out something.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 08-29-2005, 02:48 PM   #15
stllookn
stllookn's Avatar
gaskets
I am interested depending upon the price. I am in no rush at the moment since I will probably need to clean and paint the entire rearend eventually when the restoration gets further along. Right now I am just getting it back on the road and addressing the "drivability" issues.
Mike "stllookn" Kirby
Old 08-29-2005, 03:25 PM   #16
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Let me know... Oh yeah, US Gear sells rebuild kits for these type Eaton Rear ends. I sure it is a HO72, adjustable load bearing bolt on the front side of differential?
Old 08-30-2005, 05:06 AM   #17
4x4Poet
Turns out I bought an Eaton H052 rear axle housing cover gasket from BTB:
Felpro RDS 5088 Rear axle housing set
Chevrolet Truck
1937-1972
Replaces 3665606
I have my '72 pickup's Eaton H052 rear cover off, so I lined up the gasket. Fits perfect. All precut holes line up. And I thought the gasket was paper, but it is ~1/16" and both thick and rubbery, like it is rubber impregnated paper. Definitely not cork. Not just smooth rubber. It has a texture. I'm not sure what it's made of, frankly.
D.PASS, Some H052s can have the ring gear deflection bolt in the side of the third member housing. I have a '71 K20 burb with 12"x2" brakes and a '72 K20 pickup with 11"x2.5" brakes and they both have third members with the side bolt adjustment. I'm guessing the deflection bolt came on later model H052s. I'm still learning about Eatons.
Old 08-30-2005, 04:58 PM   #18
zimmm
NAPA/Victor Part No. for the rear gasket is P39130. This will be the heavier gasket material, but not cork. Just went through the same thing with my truck as well. For the 4x4's the catalog has the front and rear gasket parts numbers reversed.
72 K20 - quote upon getting it home "What did you buy it for if the brakes don't work"
98 Z71, 96 Tacoma + more toys than I can remember
zimmm is offline   Reply With Quote
Old 08-30-2005, 05:08 PM   #19
stllookn
stllookn's Avatar
Looks like my adjustment bolt is on the side. Does that mean it is an HO52 or HO72?
Old 08-30-2005, 05:14 PM   #20
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The rear end in my truck has the load adjusting bolt on the side too.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-30-2005, 06:23 PM   #21
1969 GMC
1969 GMC's Avatar
Your truck is a 3/4 ton, right? So its a H052. H072 was basically the same axle that came under one tons.
EDIT: the gear deflection bolt may be a newer thing. my '66 centersection doesnt have it, but my '68 does.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-30-2005, 07:34 PM   #22
stllookn
stllookn's Avatar
1969GMC, Thanks, that is good to know...3/4 t. - Eaton HO52. I noticed that my '72 3/4 t. Longhorn has a Dana. I guess the General used whatever arrived on the next pallet...LOL!
Old 08-30-2005, 11:19 PM   #23
4x4Poet
I have NAPA P39130 Eaton H052 cover gasket in my hands and it is only ~1/32" thick. Compared to the Felpro RDS 5088 gasket I'm holding, the NAPA/Victor Reinz P39130 gasket is only half as thick as the Felpro gasket, so I'd say the thicker Felpro version will more easily conform to irregularities in the cover/housing or different bolt torques and thereby seal better. They're made of the same stuff, though [rubber impregnated paper? Still don't know.].
I also have NAPA and Felpro Eaton H052 3rd member gaskets. NAPA P29129 and Felpro RDS 5090. They're about the same. Both thin paper, but the Felpro seems a tad better. Tough call.
I'm taking back both NAPA gaskets. NAPA's cover gasket for being half as thick as Felpro's offering and also NAPA's 3rd member gasket since I'll only have to make one return. Besides, I've already opened the Felpro boxes, but not the NAPA plastic wrap.
Thanks for the thread, stllookn. I might not have noticed the differences had you not brought it up while I had all 4 gaskets in hand with my H052 cover off. Felpro kicks @$$ this time. Now where's that receipt?
Old 08-30-2005, 11:32 PM   #24
I had to buy a big sheet of cork/rubber gasket material and make one. All I could find were the thin paper ones too, but then I screwed up and didn't put sealer on the bolts so it leaks like a SOB. I'll just wait to fix it right when I change the gear oil again.
RJD
Old 08-30-2005, 11:56 PM   #25
jostrans68
Jostrans68
jostrans68's Avatar
like this?fel pro rds5088 at schucks
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Thread Tools
Display Modes
