Old 08-28-2005, 10:02 PM   #1
chevybill
chevybill's Avatar
Talking Converting a vortec engine to carb?
I have acquired a vortec 350 out of about a 98or99 chevy truck and need to convert to a carburetor and ordinary electronic ignition. I also am considering putting regular pulleys and v belts on for a more traditional look.
What intake, distributor, carburetor, water pump, pulleys etc. do you guys recommend for this conversion? Please include part numbers if you have them.
Thanks for your replies.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 08-28-2005, 10:05 PM   #2
jamal
jamal's Avatar
You need to get a different cam gear for your distributor, and an intake for vortec heads, I would personaly run a quadrajet
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 08-28-2005, 10:10 PM   #3
chevybill
chevybill's Avatar
do you mean the gear on the distributor? or the gear on the camshaft with the timing chain? i am going to be replacing the distributor anyway.
Old 08-28-2005, 10:20 PM   #4
FormerMember
You need a different gear on your distributor.
The Vortec is a rolller motor.
FormerMember is offline   Reply With Quote
Old 08-28-2005, 10:24 PM   #5
1991s10
1991s10's Avatar
I dont think he needs the brass gear unless it's a solid roller. I didn't & it shouldn't be a solid
1991s10 is offline   Reply With Quote
Old 08-29-2005, 08:40 AM   #6
chevybill
chevybill's Avatar
thanks for the replies, how about the water pump, v belt pulleys, carb, and other items?
has anyone done this swap?
Old 08-29-2005, 09:01 AM   #7
FormerMember
I did the Vortec swap to TBI in a 91 K5. Kept the water pump and all accessories Vortec. Had to change the intake (a given), run my old distributor and use the distributor drive gear from the Vortec.
Old 08-29-2005, 09:49 AM   #8
jamal
jamal's Avatar
Dont know how to spell it but think it is called a melonized gear
Old 08-29-2005, 09:53 AM   #9
FormerMember
I used the one from the Vortec distributor on mine.
A brass one will also work, I am told. However, I haven't done this.
Old 08-30-2005, 12:40 AM   #10
xcracer
We use vortecs all the time in streetrods. We use a stock hei dist. with stock gear. The only time you need a bronze gear is with a solid roller which is forged steel. There is no way GM is spending the extra money to get forgings. As for eberything else, its just stock small block stuff as far as pulleys and accessories. Its an easy swap, and you will love the vortec 5.7.
Pete
xcracer is offline   Reply With Quote
Old 08-30-2005, 03:28 AM   #11
HeavyD
HeavyD's Avatar
What do you guys do about the fuel pump? Just run an electric Holley pump or something?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-30-2005, 08:47 AM   #12
FormerMember
Pete
That's good to know. My distro gear was chewed up, so we run what we brung.
Old 08-30-2005, 11:23 AM   #13
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
fuel pump block off plate, holley blue.
Performance Products "Hurricane" Vortec Intake (ebay) its just like a Victor JR http://cgi.ebay.com/ebaymotors/350-V...QQcmdZViewItem
GOOD LUCK I LOVE MINE !!
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Thread Tools
Display Modes
