Old 08-28-2005, 11:35 PM   #1
corn
powersteering pics?
Does anyone have a picture or 3 of a small block with power steering that they can post? I converted my sons 69 to a small block from a big block & I dont think the pump will fit the truck even with different brackets. His had the resevoir style tank. Thanks for any help...corn
corn is offline   Reply With Quote
Old 08-29-2005, 07:44 AM   #2
JimKshortstep4x4
Talking
Adapting the big block PS pump may be very difficult. I would suggest getting the pump and brackets for a small block to match the setup on your engine.
Since you changed out the engine it is also important to know if the engine has a short water pump or long water pump. It is posssible to end up with off-set pulleys when the wrong parts are used together. Piecing together power steering/pulley sets can be frustrating.
If you have a stock 69 small block engine with the original water pump then a picture or pictures can be posted.
Let us know what you have.
Jim
Old 08-29-2005, 01:52 PM   #3
68Stepbed
68Stepbed's Avatar
Not the best but these might help. If I were you I'd go with the Alan Grove bracket. The pump should be the same.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-29-2005, 07:15 PM   #4
corn
Thanks guys. I am running a long pump on it. I have a pump from my 84 but the hoses are the o-ring style & the steering box is set up for the inverted flare lines. Ill keep digging. Anyone need a big block (short water pump) steering pump?
Old 08-29-2005, 08:36 PM   #5
JimKshortstep4x4
Talking
Here is a pic of a power steering pump from the mid 70's on a sbc in one of these trucks. It is the for long water pump setup.
Jim
Old 08-29-2005, 08:42 PM   #6
alf1096
alf1096's Avatar
How do you shrink your pics down to where they are under the 100k
alf1096 is offline   Reply With Quote
Old 08-29-2005, 09:17 PM   #7
JimKshortstep4x4
Talking
alf1096,
I use a program for pictures, "Camedia" and it is very easy with this program. It has an "Image Resize" which is used to decrease the pixal size. Sometimes I get rejected for oversize but it is a simple matter of redoing the size with the program.
The "Camedia" program came with my Olympus camera.
Jim
Old 08-30-2005, 09:40 AM   #8
knsmodels
I make Models
knsmodels's Avatar
How much you want for the power steering setup you took off of the big block??
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Thread Tools
Display Modes
