Old 09-01-2005, 08:52 PM   #1
Paul72
Paul72's Avatar
Ride height question
Does anybody know if our Blazers sat 'level' when new? Here's what I mean - I thought my Blazer was sagging in the back, so I measured from the road to the top of the wheel wells, f/r, and found the rear to be 2" lower. I installed 2" blocks in the back to level it out. Galen was over last weekend and his was 2" lower in the back as well. Is that normal?
Here's a pic of the 2 blazers, don't know if it will help much...
BTW - both blazers have 31" tires.
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 09-01-2005, 10:13 PM   #2
smbrouss70
smbrouss70's Avatar
You need to measure from the ground to the bottom of the body front and rear. The wheelwells in front go higher up into the body than the rears do
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-01-2005, 11:33 PM   #3
69TowRig
Most all vehicles are like that to compensate for the front tires being able to turn while the suspension cycles.
It's deceiving to the eyes.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 09-02-2005, 06:31 AM   #4
vtblazer
vtblazer's Avatar
Seems like all the years of blazers get the dreaded 'butt sag'
Checking for level by using the bedside as a base to start from might work better/best
vtblazer is offline   Reply With Quote
Old 09-02-2005, 07:10 AM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
This is the reason the PO of "GQ" put on a 4/6 lift, he said it would sit a little
higher in the rear with the top off, and it does, but be level with the top on
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-05-2005, 04:07 PM   #6
70blazerpickup
iv never heard or seen of one that sat leaval w/ out modifacations
70blazerpickup is offline   Reply With Quote
Old 09-05-2005, 09:56 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
To me the one on the right looks like the ass is sitting high now. Wait until the top comes off. It will spring up more.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Thread Tools
Display Modes
