Old 09-03-2005, 12:34 AM   #1
Doug76
This S&*! Is expensive!
Doug76's Avatar
Widest rear wheel possible?
Whats the widest rear rim/tire combo you can run on the rear with a coil spring rear?
Doug76 is offline   Reply With Quote
Old 09-03-2005, 01:31 AM   #2
raidermanny
raidermanny's Avatar
I'm wondering the same thing
raidermanny is offline   Reply With Quote
Old 09-03-2005, 01:32 AM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
I believe the widest rim you can run is 12in. I have no clue what size rubber would work.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 09-03-2005, 01:41 AM   #4
Rokcrln
Rokcrln's Avatar
I am running 11" rims with 335/35/17's they are the dodge vipper tires. I had to do a mini tub to the bed but now I think I want bigger. I can fit about a 12-13" rim and would love to find a 355 for the back in a 20" rim dia.
Kevin
Rokcrln is offline   Reply With Quote
Old 09-03-2005, 06:53 AM   #5
lowrider79
I have 10 x 15 rims, P295 50 R15's. I did not have to modify the body. They protrude about 1/2" from the outside of the side of the truck. I believe the offset is 4 or 4 1/2 inches on the rim. The tires on that rim measure 12 7/8 inches wide.
lowrider79 is offline   Reply With Quote
Old 09-03-2005, 05:03 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I have 33-12.5-16.5's on the back of my truck with 16.5x9.75 rims. The acutal width from lip to lip on the rims is 12 and that's as wide as I'd go. I also have the original cab and chassis rear so it's kinda narrow.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 09-03-2005, 05:23 PM   #7
kingsolver72
10/30/19
kingsolver72's Avatar
I have 12" rims with a 7" backspace,tires are P295/50R15 on my 69,Mine to is tubbed out.
kingsolver72 is offline   Reply With Quote
Old 09-03-2005, 08:00 PM   #8
SCOTI
SCOTI's Avatar
I used to have 15x14" vette-ralleys w/31x18.5x15 Mickey T Sportsmans on a stock width 67/8 12-bolt, coil spring suspended, stock frame rail 68. All that was required was removal of the outside bumpstop, mini-tubbing & custom off-set wheels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-03-2005, 08:25 PM   #9
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
I was running around 8 or 10" wide aluminum slots with N50 tires on my truck. From what I remembered, they would rub on the inside of the rear wheel well whenever I turned a corner. Otherwise they fit in the opening perfectly.
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
Old 09-04-2005, 01:30 PM   #10
Doug76
Doug76's Avatar
Man thats alot of tire..I would be interested in the specifics on how much you took out of the bed..I thought about doing some aluminum wheel tubs myself. Do you have any pics of the rear setup?
Thanks,
Doug
Old 09-04-2005, 04:01 PM   #11
SCOTI
SCOTI's Avatar
Originally Posted by Doug76
Man thats alot of tire..I would be interested in the specifics on how much you took out of the bed..I thought about doing some aluminum wheel tubs myself. Do you have any pics of the rear setup? Thanks, Doug
The rear set-up was just an average stock length 67-68 12bolt rear housing. The mods were just to the floor & tubs + the custom offset wheels. I cut the floor all the way to the outer edge of the frame & had the stock tubs stretched to fit. I also stepped the bed floor for clearance since my truck is pretty low.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-04-2005, 04:14 PM   #12
72CSTC5
72CSTC5's Avatar
The bed of your truck looks good. Nice job.
72CSTC5 is offline   Reply With Quote
Old 09-04-2005, 04:25 PM   #13
SCOTI
SCOTI's Avatar
The bed floor measures 19.5" from the cut line to the original outer edge.
Thanks for the props. I did the floor w/the help of a friend that specialty welds thin stuff (aluminum mostly but sheetmetal too) in a sheetmetal fab shop. Another friend helped significantly w/the tubs.
I can't take the credit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-04-2005, 05:06 PM   #14
Purs
Got Big Block?
Purs's Avatar
beautiful! I hope turns out 1/2 that good.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 09-04-2005, 07:46 PM   #15
BowTieMan
BowTieMan's Avatar
Got any pictures of it with the wheels on there?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 09-04-2005, 08:02 PM   #16
SCOTI
SCOTI's Avatar
Only pics I have are some older prints but I don't have a scanner.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-04-2005, 08:19 PM   #17
Oborny71
Oborny71's Avatar
I'm running 325/50s on a 15x10" rim with about 3/4 inch to spare on each side without any modifications. my truck has a 4/6 drop. keep in mind the 69-72 rearends are wider by about 1 1/2" . I am running a 71' rear in my 67' .
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 09-05-2005, 12:02 AM   #18
Doug76
Doug76's Avatar
Scoti What offset are you using for the wheel?
Old 09-05-2005, 12:12 AM   #19
Robznob11
Robznob11's Avatar
mine are
i have 12 wide drag lites with 6.5 bs im going to try to fit a 29.15.5 under there its probably going to be tight i have a 68 12 bolt measurements shows it will clear to be safe get the 7.5 bs you do have to tub it though
Robznob11 is offline   Reply With Quote
Old 09-05-2005, 03:34 PM   #20
twisted racing
Hey can you tell me what size rims and tires you are going to run with the back spacing too, my bed looks just like your but i havent finshed it yet and is your rear end 5 or 6 lug thanks alot if you cna help me
twisted racing is offline   Reply With Quote
Old 09-05-2005, 04:04 PM   #21
SCOTI
SCOTI's Avatar
It had 15x14" steelies w/9.75bs & 21x18.5x15 Mickey Thompson Sportsmans. That worked for me but you should measure your own combination to be sure. Since the rear wasn't narrowed & I used custom back-spacing, you have to be able to drop the suspension to fit the wheel/tire into place. No big deal but it was extra work.
I'll be putting some 20x11 or 12" wide wheels on there now. The big tire thing was temporary.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-05-2005, 04:08 PM   #22
Purs
Got Big Block?
Purs's Avatar
do you have any good pics with that combo? thanks!
Old 09-05-2005, 05:10 PM   #23
SCOTI
SCOTI's Avatar
Sorry . . .....
Wheels & tires are long gone now.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-05-2005, 05:24 PM   #24
Purs
Got Big Block?
Purs's Avatar
sorry SCOTI, just reread the whole post....
Old 09-05-2005, 06:26 PM   #25
SCOTI
SCOTI's Avatar
Not a problem.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Thread Tools
Display Modes
