Old 09-04-2005, 05:03 PM   #1
rchdrm
The start of the $ pit!
rchdrm's Avatar
Colapsing the column
I have seen the thread about installing a tilt wheel and will do that as soon as mine arrives but I had a question in the mean time.
Can you colapse the column to any dimension you choose? I'm sitting too close to the wheel.
rchdrm is offline   Reply With Quote
Old 09-04-2005, 05:26 PM   #2
SCOTI
SCOTI's Avatar
Actually, the collapsable (sp?) part is under the hood & not in the cab. Your stuck w/that as far as stock GM columns go. They do make a shorty aftermarket ($$$$) column for GM applications w/limited space. I bet one of those could be converted to work, but kind of pricey.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-04-2005, 06:05 PM   #3
neonlarry
neonlarry's Avatar
To answer your question yes within reason. The limiting factor will be clearance for the N\S switch. The part that is collasped is the intermediate shaft. See here:
http://67-72chevytrucks.com/vboard/s....php3?t=133937
If you place the N\S switch right on the van column you should be able to get as much room as you want again within reason. See here:
http://67-72chevytrucks.com/vboard/s...threadid=63328
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-04-2005, 06:07 PM   #4
Custom_C5
Actually you can move the steering wheel to the dash as close as you want it, here's a pic of a '68 column.
Custom_C5 is offline   Reply With Quote
Thread Tools
Display Modes
