Old 09-04-2005, 10:44 PM   #1
rmrtndl
Hey ya'll, Watch this!
rmrtndl's Avatar
One Man Cab Removal
Today I removed my cab. The engine hoist along with a couple of pieces of 2x4 allowed me to remove it by myself. No other special tooks required. I put it down on jack stands but plan on making a cab dolly soon.
The 2x4 is balanced on the top end of the hoist. It was fairly easy to get it balanced. As you can see cab is front heavy. I would have prefered a 4x4 but didn't have one handy. Becareful if you try it yourself.
Plenty of rust to remove, but the frame needs a lot of work first.
Rick M.
72 GMC SWB Fleetside
25 Chevrolet Superior Series Truck
95 Mazda Miata
06 Dodge Charger RT
http://ram92.ods.org/blog.html
rmrtndl is offline   Reply With Quote
Old 09-04-2005, 11:04 PM   #2
longhorn71
longhorn71's Avatar
Great idea ,looks like it worked good too!!!That cab has rust? not much compared to mine.Keep us posted on your progress
longhorn71 is offline   Reply With Quote
Old 09-04-2005, 11:07 PM   #3
oldschooloutlaw
oldschooloutlaw's Avatar
that cab looks great to start with , it still has rockers and front floor pans
Drive fast and Take Chances - In memory of Todd Rowe #725 Fire Chief
96 Chevy K1500
67 Chevelle
70 Chevy C10 - Old Red
oldschooloutlaw is offline   Reply With Quote
Old 09-04-2005, 11:11 PM   #4
Chevy_Man
Tightwad
Chevy_Man's Avatar
Like the idea, i have been wondering how i could get my cab off by myself.. Now i have it.. thanks for the idea, keep us posted on the progress of the frame and cab.
thanks,
eric
Chevy_Man is offline   Reply With Quote
Old 09-04-2005, 11:13 PM   #5
rmrtndl
rmrtndl's Avatar
Oh yeah, there is some rust. It needs 2x inner and outer rockers, cab corners, cab supports, A-pillars, driver side floor, and a good bit of work on the floor. I am probably going to check out the available cabs at the local salvage before I proceed with it.
Compared to some, I may have it easy in the rust department, but having never done this type of work before, there are times when I don't know how to proceed. I guess my confidence will increase as I get more welding experience.
Rick M.
95 Mazda Miata
06 Dodge Charger RT
Old 09-04-2005, 11:57 PM   #6
Batmat
I lifted my cab the same way, except I used two long tie down straps. I looped around the rear of the cab and the other around the front, then hooked them together on the engine hoist. I didn't know if the roof would support the cab weight, but your way worked out great. Good thinking!
Batmat is offline   Reply With Quote
Old 09-05-2005, 06:10 AM   #7
panhandler62
Java Mechanic
panhandler62's Avatar
I think you'll probably loose the glass if you left it in. It eouldn't take much flex to crack the windshield.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-05-2005, 08:52 AM   #8
rmrtndl
rmrtndl's Avatar
I considered running the 2x4's thru the doors. This would have required the 2x4's to be twice as long and I was concerned that they might flex and possibly crack. I thought it might be easier to balance the way I did it.
If anyone tries it the other way, let us know how it works out. Had I run the board thru the doors I would have definitely used a 4x4.
I agree with panhandler62 regarding the glass. I suspect it would crack due to even a small bit of flexing. My windshield already had a chip and small crack so I took it out.
Has anyone tried rolling the cab over on it's back? I think it might be easier to work on the cab supports this way but I am concerned about it being top(front) heavy.
Rick M.
95 Mazda Miata
06 Dodge Charger RT
Old 09-05-2005, 09:47 AM   #9
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
We balanced Striker's cabs on their back side while swapping them out. They balanced pretty easily. Don't know how long they could hav stayed without flexing, though.
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 09-05-2005, 10:14 AM   #10
Randy70C-10
Randy70C-10's Avatar
Damn, that was a great idea! (wish that I had thought of that two months ago)
Randy70C-10 is offline   Reply With Quote
Old 09-05-2005, 03:33 PM   #11
Joe67
67 is sold
I used an engine hoist to remove mine as well, with the windshield and backglass intact
I used a 2x6 from side to side inside the cab and used a 2" car tie down strap around that and used the boom outside the cab roof. That allowed me to roll it about freely.
I'm curious how you moved it around with the boom inside like that on the wood, it didn't want to slide off when you moved it around like that?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-05-2005, 08:45 PM   #12
rmrtndl
rmrtndl's Avatar
The cab is heavy enough that the boom just didn't want to slide. There was a minor indention in the 2x4 where it contacted the boom. That could have provided just enough friction to resist sliding.
Rick M.
95 Mazda Miata
06 Dodge Charger RT
Old 09-05-2005, 09:46 PM   #13
cduster
I ran 2 2x4's through the doors when I removed my cab, and balanced them in the cherry picker the same way. The boards bowed some, but no cracking glass or anything like that. I also rolled the cab over on its back to work on it. No problems whatsoever.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 09-06-2005, 07:37 AM   #14
Joe67
67 is sold
Originally Posted by rick980
Now that is what I would do,they must put a hole in the wood eh? So your glass didnt crack, I didn't think it would thru the doors.. Those cabs seem really solid to me. I am gonna use Joe's method but or I am just gonna put a 3 inch tie down thru it no wood..since I have them..what do you think? The dam things are 30 feet long.
I used the wood as extra support, but also so the straps wouldn't distort the metal in the top of the door window frames nor the roof rail gutters on either side
Old 09-06-2005, 09:16 AM   #15
Russell
Professional Grade
Russell's Avatar
I just used a couple straps hooked up to the skid steer, lol
I had mine sitting on it's back for weeks with no problems, and it is a more flimsy 73-80 cab
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-07-2005, 12:02 AM   #16
junkyarddog67
cab removal
I have removed several cabs with the bucket on my tractor and a 3 inch sling through the door openings. Never had any problem with flex and or cracked glass. They are pretty sturdy.
junkyarddog67 is offline   Reply With Quote
Old 09-07-2005, 12:31 AM   #17
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
I've done it too.
Use a 2x6 through the doors and a 2" straplooped around the ends to the boom over the top of the cab.
Used an extended boom on the picker and rolled the chassis out of the way.
The cab had no doors but did have front and rear glass.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 09-07-2005, 01:11 AM   #18
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool
I just LOVE the GM Red/White combo in these years!!!
I am jealous!
Anyways, so many ways to think these out, that is why this site is the BEST around...
Having 2 trucks of my own, and limited space and tools, researching this site from time to time can really be a world of worth thru invention!
I look at all kinds of Metal contraptions we all make and post, but I must add this link to this Thread as it was already discussed on this site in the FAQ tab!
( But...rmrtndl 's Wood version keeps the costs down and keeps us within our budgets of our goals ! )
I believe that this gentleman's set-up is just about what any of us would desire! :
Link:
http://67-72chevytrucks.com/vboard/s....php3?t=113397
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 09-07-2005, 08:07 AM   #19
Joe67
67 is sold
Link:
That is a good idea
Old 09-07-2005, 09:13 AM   #20
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Here is how I did mine. Chain hoist on the cab with a 4x4 square tube throught the doors, cherry picker (engine hoist) attached to the core support.
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 09-07-2005, 10:32 AM   #21
RPOZ11
RPOZ11's Avatar
Cool
That is a good idea
I keep looking at this one and think that the pivot area needs a base to spin on or even a bearing to spin on
Would also consider getting that U-channel on the top of the Hoist arm more flush on the top of the arm so as not to rock fore or aft!
HO72 build :
2017 SS
Old 09-07-2005, 10:35 AM   #22
RPOZ11
RPOZ11's Avatar
Cool
Chris H :
I want a Barn like that!!!!
I can only dream to have my backyard twice it's size to fit that of what you have!
HO72 build :
2017 SS
Thread Tools
Display Modes
