07-01-2002, 03:43 PM | #1 |
where to buy - VACUUM SWITCH
Please help. I'm wondering where to buy a
Vacuum distribution switch/valve. (it's the one that mounts to the top of the heater/AC controls and controls vacuum to the different air doors) mine was ruined when the heater shut-off valve (in line on heater hose) failed and sent coolant through the vacuum line to the switch/valve. the local parts stores can't get one. the dealer says it was discontinued in 1985. LMC, Golden, Harmons and others say they don't have one either. so far, the only way I've found to get one is by buying the entire control assembly for $130-$180! PLEASE ADVISE thanks in advance |
07-01-2002, 08:22 PM | #2 |
ttt - please. it's over 100 degrees & I need AC
07-01-2002, 11:05 PM | #3 |
67-72 Addict!
Looks like you'll have to suffer like the rest of us, LOL. Try www.gmcpauls.com , he might have it. Good luck
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-11-2002, 01:36 PM | #4 |
I need one of these also, So someone plaese help!!!
There is a GM p/n on the switch so GM may be able to get one. My truck isn't running right now so it has not been a priority for me. |
07-11-2002, 02:56 PM | #5 |
CCRider
That switch only operates the heater control valve and the fresh air control. Both can easily be bypassed if it is hot outside, so there is no reason not to enjoy your A/C till you find one.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
07-11-2002, 08:17 PM | #6 | ||
http://s-c-t-p.com/ for $2. it only had 2 vacuum nipples while my switch had the elusive "third nipple". so I tee'd the hose to the heater valve in with the air door hose. we'll see... J |
Thread Tools | |
Display Modes | |
