Old 09-14-2005, 06:38 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Question I need rear brake help...HELP
I just recently put the brakes back on my rebuilt 12 bolt rear end. Put it back the same way I took it off. I have rolled the frame in and out of the garage a couple of times. When I pused it backwards I could hear the brake adjuster clicking. Well now the frame will not roll at all. I realize the brake adjuster has pushed the brake out which is preventing the wheel/drum from turning. How can I fix this. There is not brake fluid in the lines and I removed the e-brake cables from the rear drums (waiting to buy new ones)
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-14-2005, 07:21 PM   #2
neonlarry
neonlarry's Avatar
Just pop off the little cover and adjust the star wheel to loosen the brake shoes.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-14-2005, 08:40 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
I will try that, but what do I need to fix to stop it from doing the samething again?
Anyone.......... I am stumped and a little frustrated.
Old 09-14-2005, 10:59 PM   #4
jugernot
Life, Be In It.....
jugernot's Avatar
ttt
Old 09-15-2005, 10:20 AM   #5
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
did you get the star wheel / spreader assembly installed in the correct orientation?
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 09-15-2005, 11:24 AM   #6
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Back the adjuster star down until it bottoms out snuggly.
The adjuster will just slide over the star wheel.
Adjust the brakes back up when you are ready to go on the road.
The way it is adjusting the brakes now is proper.
oldiron is offline   Reply With Quote
Old 09-15-2005, 11:37 AM   #7
cdowns
cdowns's Avatar
if the brake adjusters tightened up by pushing backwards something is not installed properly they're supposed to adjust with the application of the brakes while in reverse not just by the wheel going in reverse
Old 09-15-2005, 12:55 PM   #8
68 short step
buy a set of car dollies.jack up the rear , slide dollies under tires , lower truck on dallies. problem solved...
68 short step is offline   Reply With Quote
Old 09-15-2005, 01:27 PM   #9
tomatocity
tomatocity's Avatar
Agree with cdowns. I wonder if the adjusters are directional and that you might have mistakenly installed them either backwards or on the opposite side. Logical thoughts not knowledgable thoughts. What do I know about brakes?: big shoe in front, white lithium grease, can be a PIA. Do you have any pics?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 09-15-2005, 03:21 PM   #10
jugernot
Life, Be In It.....
jugernot's Avatar
I will get take some pics of the problem brake.
Tomatocity-which junk yard in Sac are good for parts? I am not looking for anything right now, just interested in which yards to go to.
Old 09-15-2005, 05:31 PM   #11
jugernot
Life, Be In It.....
jugernot's Avatar
Up loaded some pics. Can anyone tell me I put it back together correctly. There are no emergency brake cables installed.
Old 09-15-2005, 05:43 PM   #12
blazerparts
looks right, adjusting mechanism anyhow
Old 09-15-2005, 06:12 PM   #13
jugernot
Life, Be In It.....
jugernot's Avatar
I had made some adjustment, put everything back on, them rolled the tire backwards and forwards. I did not hear the adjuster clicking. So I think I fixed it. We'll see the next time I try to roll it out of the garage.
Thanks everyone.
Old 09-15-2005, 06:13 PM   #14
cdowns
cdowns's Avatar
the flat bar with the little spring is backwards//spring should b opposite side of adjuster arm / both ends of that arm go on brake shoes and the cutout is to clear the axel//
not pickin on you but an excellent example of why to only do 1brake at a time//or take pictures B-4 removing
Old 09-15-2005, 08:16 PM   #15
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i dont knowits hard to see but is the primary shoe on front and rear in the picture
they look like the same size shoes when the secondary shoe should be longer
maybe on the other side you got two secondary shoes on
hard to say by the picture
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-15-2005, 08:25 PM   #16
68 short step
looking at the pics. which way is the front of the vehicle?
Old 09-15-2005, 08:27 PM   #17
fastwillie 696969
~Rest In Peace~
Thumbs up dude ebrake assy always
dude e brake assy always goes to the rear so the front of the truck is pointing to the left in the picture
Old 09-15-2005, 08:44 PM   #18
jugernot
Life, Be In It.....
jugernot's Avatar
I will have to pull the other wheel off and check that. I made sure when I removed them, before rebuilt, that I kept them seperate. Thanks
Old 09-15-2005, 09:50 PM   #19
68 short step
yes i know. i was asking for that same reason. I know and YOU know, but it is possible that other people DONT know. dude
Old 09-15-2005, 10:37 PM   #20
86SILVERADO
86SILVERADO's Avatar
The shoes are on the proper sides in the pic. The primary shoe is to the rear as it should be.....if that is actually the rear of the truck.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 09-15-2005, 11:20 PM   #21
jugernot
Life, Be In It.....
jugernot's Avatar
Thanks for the input, are you refering to the spring and flat bar behind the axle hub and touches each brake shoe?
Old 09-16-2005, 09:19 PM   #22
cdowns
cdowns's Avatar
yes you have to flip the bar and spring endfer end spring side toward the front
Old 09-16-2005, 09:41 PM   #23
Z28Owner
Z28Owner's Avatar
I just went through this hell today, should have waited till a better parts store could get the parts in. But no, had to get it done today Never again will I get the autozone junk. The wheel cylinder wouldnt even fit on drivers side, also it uses a metric for bleeder. Had to file and file on the part that the cyl fits in between. But I had one leaking and brakes where dragging bad. Stops good now though, hope all them parts hold up.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Thread Tools
Display Modes
