09-16-2005, 03:31 AM | #1 |
70-72 5 bolt in 60-66 coil chassis????
will a 70-72 5 bolt coil rear bolt into the 60-66 coil chassis?
if so,,,,,, anybody got a 5 bolt 3.08 rear for sale? PM me with your parts if you got 'em _
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
09-16-2005, 06:51 AM | #2 |
They're a little wider (.75 each side) but otherwise yes a bolt-in swap. The 67-69's 12-bolt are the same length.
A friend of mine swapped a 72 5-lug 12-bolt into his 66 & used 5-lug 15x8 truck ralleys w/o any problems.
09-16-2005, 08:12 AM | #3 |
Watch out for your cornhole !
Up through 64, the panhard bar is different. On these earlier rearends, the bar mounts to a big bracket on the right axle tube rather than the top of the pumpkin like the 65 and laters do.
If you swap a 65 and newer rear into a 60-64 truck, you have to also change the frame bracket for the panhard bar out with a later model one and use the later panhard bar too. I just ran into this on my 64 Suburban.
09-16-2005, 02:26 PM | #4 |
Oh yeah . . .... the pre-65's have different pan-hard bar mounts & also use the 'drop-out' style rear end similar to a 9". I should have included that.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-16-2005 at 02:27 PM. |
Thread Tools | |
Display Modes | |
