Old 09-19-2005, 06:50 PM   #1
big72red
How much lift do I need?
My dream truck is a 1972 Chevy 4x4. I want to run Toyo Open Country A/T's on it. The size I want to use is LT315/75R16. It is supposed to be about 35"x12.5"x16". I think they actually measure 34.57" diameter. I do not want to trim the fenders at all. Can I get by with a 4" lift, or do I need to just go ahead and get a 6" lift? Thanks in advance for any help.
big72red is offline   Reply With Quote
Old 09-19-2005, 09:34 PM   #2
countryboyz71
countryboyz71's Avatar
a 4" lift well enuff for a 315 tire size
countryboyz71 is offline   Reply With Quote
Old 09-20-2005, 09:03 AM   #3
...with 8" rims.They will fit w/10" for a cruiser that you`re being very careful with to avoid rubbing.If you want "true" clearance,I`d suggest 6".
Old 09-20-2005, 06:44 PM   #4
big72red
Thanks a lot y'all! I will get a six inch lift if I go with those tires. I've been considering using the LT295/75R16's instead. They're only 33.3" so if I get them I'll use 4" of lift. Can't make up my mind yet. Thanks again.
Old 09-21-2005, 09:14 PM   #5
hilljob26
hilljob26's Avatar
if you go with the 6",i have a set of new front springs i will sell for cheap,like 200
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-22-2005, 01:22 AM   #6
mx jim
I have a 70 4x4 and i have a 4" lift with 35x12.5 15 with a 8" wheel. I have no problem with rubing at all they fit Great.
mxjim 1970 chevy 4x4, 400 small block, 4" pro comp lift, with 35s.
mx jim is offline   Reply With Quote
Old 09-23-2005, 04:21 PM   #7
big72red
Thanks for the feedback guys. I don't even own the truck yet, so you should probably sell those springs to someone else. Thanks anyway though!
Old 09-23-2005, 05:02 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Very close to my set-up, my Blazer has a 4/6 lift, same size rims and tires
*On a side note, if the PO had not lifted before I bought it I would have gone 6/6
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Thread Tools
Display Modes
