Old 09-19-2005, 10:14 PM   #1
72GMC51
72GMC51
72GMC51's Avatar
Drive line vibration
I have the truck together and have test driven it several times, the problem is a vibration that seems to get worse the faster I go. Had the drive shaft balanced and new joints installed. How would you check a two piece drive shaft angle, I thought because it was two piece that the rear end trany angle did not matter because of the carrier bearing, if this is not right how do you set the angle since the drive shaft flexes in the middle. Also any ideas as to what might cause the vibration, I lowered the truck 3" in back and 2" in front installed sway bars on both ends and had a eaton posi with 4:10 gears installed and I have 700r4 trany (which I am having issues with getting the TV cable adjusted properly).
JC
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10.
Are they ever really finished
72GMC51 is offline   Reply With Quote
Old 09-19-2005, 10:55 PM   #2
mbgmike
you can run the motor without the driveshaft attached and run it up to driving rpms and see if it vibrates. if it does run it without the trans attached and see if it still does. it could be an unbalanced flex plate.
mbgmike is offline   Reply With Quote
Old 09-20-2005, 09:33 AM   #3
69 longhorn
A driveline "vibe" can make you nuts chasing it (been there). I agree, that the 1st thing you need to do is decide if its in the shaft, or the engine. If you can rev the eng in park or nuetral, & feel the vibe, its in the engine, or flexplate/converter. if thats the case, i would mark the converter & flexplate for location, then unbolt the converter & push it back from the crank.start it up..... if you still have a vibe, you know its in the flexplate, or the engine balance. if the vibe goes away, you need to try indexing the converter to a different spot on the flexplate, & bolt it back up(you have 3 spots on a chevy to try). If you dont find the Vibe in the engine, its time to play with the d shaft. The front 1/2 of the shaft should be pretty much straight off the trans output shaft(you might go about 1/2 degree to work the grease into the U joint). the rear 2 u joints need to egual, but opposite angles. from there, you need to know that the 4.10 gears that you added spin the shaft much faster @ any given speed than say 3.07 gears, & if there is a little problem in the shaft it will be more noticeable. One trick old rodders do, (assuming alll the above checks out), & the balance is good on the shaft.....unbolt the shaft from the rear diff, & rotate it 180 degrees ,& bolt it back up. it doesnt make a lot of sence.......but sometimes this helps. Best of luck, 69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 09-20-2005, 10:06 AM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
are you sure it's not the tires?
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 09-20-2005, 04:31 PM   #5
69 longhorn
Yes, that is very possible, that problem could be in a tire, or an axle 69L
Old 09-20-2005, 06:05 PM   #6
Big Block
Big Block
Big Block's Avatar
I had a bad rear axle bearing that was causing vibration. I had the drive shaft balanced, install a new engine and trans and still had vibration. A bent rim or out of balance tires can also cause vibrations. Good luck tracking it down. B.B.
Big Block is offline   Reply With Quote
Old 09-20-2005, 10:27 PM   #7
MrC1
Dork For Days
MrC1's Avatar
Pinion angle gets my vote
My experience has shown that a vibration like yours that just can't be found by the normal initial means (DS checking, bearings, tires, etc.) always turns out to be the pinion angle, or u-joint angle. Since you said you just lowered it, the liklihood is even greater.
MrC1 is offline   Reply With Quote
Old 09-20-2005, 10:44 PM   #8
86swb
Born a Chevy Man
86swb's Avatar
I had the same problem once and come to find out it was a bad tire. I was lucky. That was the first place I checked.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 09-21-2005, 12:25 AM   #9
masterbeavis
Having issues
masterbeavis's Avatar
soemtimes binding the bearing cap on a ujoint will cause vibration (read improper installation) When you take the driveshaft off, twist the cross, if it is really tight, the caps are pressed in too tight.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-21-2005, 02:11 AM   #10
72GMC51
72GMC51
72GMC51's Avatar
I have not had much time too work on the 72 I am getting my newest ride 94 GMC 1/2 Extended ready to take a ride to Chicago to look at a 91 z28. But I did run the engine up through the rpm range in nuetral and I can feel the vibration not as bad but its there. Thanks for all of the replies.
JC
Thread Tools
Display Modes
