Old 09-21-2005, 05:37 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Thoughts on the removal of inner fenders with 20's
My 20's rub a little on the inner fender. I was thinking about removing them. Can I get some pros and cons on doing this. I don't drive my truck daily and maybe not even weekly.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 09-21-2005, 05:45 PM   #2
powell72
powell72's Avatar
Pros would be it is the easiest fix. Cons would be a dirty engine compartment if you were driving in the rain and not having inner fenders kind of makes your engine compartment look unfinished, which isn't a big deal unless you go to shows. It certainly wouldn't be a problem if you aren't driving it daliy.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-21-2005, 05:47 PM   #3
alf1096
alf1096's Avatar
I would take and cut the part that is rubbing out that way you could get the best of both worlds but if you take them out I wnat them
1970 Short Stepside----Process of Restoring
1983 1/2 Silverado
alf1096 is offline   Reply With Quote
Old 09-21-2005, 06:08 PM   #4
pjmoreland
pjmoreland's Avatar
I suppose there's a chance your front wheels could throw the occasional rock up against the bottom of your hood and dent it.
pjmoreland is offline   Reply With Quote
Old 09-21-2005, 06:12 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
and I'm not so sure it's a been there, done that w/ my 67, just say
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-21-2005, 06:26 PM   #6
chevyfarmer
chevyfarmer's Avatar
Where does it rub at? Would it be possible to cut out the section where it is rubbing, and possibly do some metal work? Metal work meaning; create a bulge and weld it back in the cut out section?
Option #2 BFH..... but your truck looks way to nice for that...
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 09-21-2005, 06:59 PM   #7
cdowns
cdowns's Avatar
crap would be forced back into the impossible to clean recesses of fender door area promoting rust an rot//as stated an ocassional dent in the hood//maybe a loose rock flyin into the radiator or battery area //but an easy way out to solve your clearance issues
Old 09-21-2005, 09:15 PM   #8
Stroker
I would go for option #1
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 09-21-2005, 09:27 PM   #9
Randy70C-10
Randy70C-10's Avatar
Funny that nobody mentioned this, but one thing that you'd definately chance is overheating. The inner fenders help seal the space that the engine is in, helping the fan to draw air through the radiator. I wouldn't have believed it if I hadn't seen it for myself, my buddy's Camaro overheated on the way to a cruize-in after removing them. After we put them back on it never overheated again.
Randy70C-10 is offline   Reply With Quote
Old 09-21-2005, 10:27 PM   #10
XXL
Señor Member
XXL's Avatar
I believe slammed67 channeled a pair of inners a couple of inches to address this issue. Check with him.
XXL is offline   Reply With Quote
Old 09-21-2005, 10:46 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Randy is right... overheating can be an issue, but not likely...I too have seen it happen though.
Old 09-22-2005, 06:27 AM   #12
NORCAL_GUY73
NORCAL_GUY73's Avatar
There was a pretty good tech article in street trucks or sport truck a month or so ago where a guy built some from a wheel tub kit. they turned out pretty nice and he was tuckin' 22's on a newer truck (blue standard cab chevy) it was the cover truck and they looked real clean, and according the to article, they weren't tooooooo difficult to fab up from the kit.
Just one option, as I am looking for the same answer....
NORCAL_GUY73 is offline   Reply With Quote
Old 09-22-2005, 09:11 AM   #13
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
Also without the inner fenders, it will catch alot of air under the hood and engine compartment at speed. Adding lift. Of course you won't be driving at those speeds.
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 09-22-2005, 07:16 PM   #14
SCOTI
SCOTI's Avatar
Don't do it. It makes things look unfinished or left out.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-23-2005, 11:09 AM   #15
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
SactoC10 used to drive around without his. I thought it looked pretty cool. We get next to zero rain out here during the summer though.
chickenwing is offline   Reply With Quote
Old 09-23-2005, 11:49 AM   #16
fletch4x4
fletch4x4's Avatar
I drove from TN to CT with out them. But the truck is torn apart now, and i plan to do something like this when i get that far along
http://www.fullsizechevy.com/forums/...d.php?t=174616
Bagged/Turbo 1970 GMC C-10
Crew Cab 1984 Chevy R-20
fletch4x4 is offline   Reply With Quote
Old 09-23-2005, 11:54 AM   #17
67ChevyRedneck
67ChevyRedneck's Avatar
I'm guessing the pics we're supposed to see are the 3 that have a link to them? When I click on them it asks for a username and passwork, could you post them on here? I guess I've never understood the big rim craze, but maybe some 18's would work better for you? If not, I'm sure you want to keep whats on there now, I'd try the cut and weld boxes on the fenders for more clearance idea.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
Last edited by 67ChevyRedneck; 09-23-2005 at 11:55 AM. Reason: I'm lysdexic and can't spel
67ChevyRedneck is offline   Reply With Quote
Old 09-23-2005, 12:30 PM   #18
fletch4x4
fletch4x4's Avatar
sry, here are the pics
and they were bought here:
http://www.etrailerpart.com/mywebs/m...8e_1801069.htm
http://www.etrailerpart.com/mywebs/m...32_2028176.htm
Oh, and I dont have 20's They were 18's with some beefy tires.
*edit yes i relaise that you might not be able to use your stock hinges and that these are on a 88-98 truck. But it gives you an idea.
Old 10-06-2005, 01:02 AM   #19
bs25j
bs25j's Avatar
you could try going with thinner tires.. How low is your truck cuz im trying to fit 22's under my 68 and ive already lowered the frnt 2 inches..
bs25j is offline   Reply With Quote
Thread Tools
Display Modes
