09-21-2005, 07:27 PM | #1 |
Junior Member
Front axle.... what does it fit?
This front axle was in the bed of my '67 2wd when I bought it??? Can anyone identify it and tell me if it's worth anything? It has 3.73 gears in it and has the drag link, pitman arm, and tie rods with it. 6 lug, drum brakes. Thinking about listing it but I need to know for sure what it fits.
Thanks, Scott
'67 SWB big block project '85 C60 school bus motorhome conversion |
09-21-2005, 07:52 PM | #2 |
It looks like a 67-70 K-10 front axle since has drum brakes.
Jim |
09-21-2005, 08:12 PM | #3 |
user # 2756
I'd have to say 70 only as it has open knuckles w/ drums.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
09-22-2005, 05:56 AM | #4 |
Junior Member
Value?
Any idea what it's worth?
Scott
09-22-2005, 06:30 AM | #5 |
user # 2756
Scott, unless you can find a need for any parts off of it, I'd say not much. Really no benefit to swap in a drum brake front when disc brake fronts can be had for a couple hundred, if that.
09-22-2005, 07:12 AM | #6 |
Does it have a posi?
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
09-22-2005, 09:39 AM | #7 | |
09-22-2005, 05:14 PM | #8 |
Junior Member
Thanks guys!
No posi. I guess I'll clean it up, check it over, and see if anyone needs any or all of it. It's just in my way now! Scott
Thread Tools | |
Display Modes | |
