hey everybody,just picked up a 79 c10 2wd shorty..with an 80's to low 90's 350 and an edelbrock manifold,some kinda double pumper holley..this thing sucks gas like no tommorrow.would like some opinions on a different carb..thinking about an edelbrock performer 600cfm?
qjets are decent carbs.. have heard holleys are hard to keep tuned.. but not personal experience there.... what kind of manifold is it? just cause its an aftermarket edelbrock doesnt mean its good for the truck..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
not sure,not a whole lot of markings looks older can't find a number on it.would like some help on identifying it as well as the motor.i've goofed around with old fords for so long i forgot all the chevy #'s.
Project 2 Resume
Personally I'd go with a Q-jet or since you're experienced with older fords, an adapter plated Holley 4412 500cfm 2 barrel. I'm not a fan of the edelbrock carter deals.
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
If it is a stock motor you could go with the q-jet. When properly rebuilt they are pretty good carbs. The other option I would recommend is a 600 or 650 with vacuum secondary. If you drive it daily put the electric choke on it since I'm sure it can get little cold in Washington. If it is a fair weather truck you can forget the choke if you want.
Shaved '77 Silverado |
Gentleman Jim Driver
I've never had the problems with Holley carbs that lots of people talk about, but a double pumper is definately not the way to go on one of these trucks. I'd get either a 600 cfm Holley with an electric choke and vacuum secondaries, a 600 or 650 Edelbrock or a Quadrajet. I've run them all and the Quadrajet gave me the best mileage but not by much. I have the easiest time tuning Holley carbs and ran one on my 84 for 8 years before I switched to fuel injection last fall.
What kind of mileage are you making now? Are you sure the rest of the engine is all up to snuff? Vacuum leaks, ignition problems, transmission or even tire pressures can all affect mileage too. In the days of $3 a gallon gas, it's worth it to look over everything!
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed Last edited by ElGracho; 09-27-2005 at 12:22 AM. |
Just thought of something else. The quadrajet and Holly mount differently. The quad mount are nearly a perfect square as the holly mounts are rectangular. The manifold may dictate the carb selection unless you get an adapter.
yeah, never thought of that.i got to find some way to figure out what exact motor and intake this thing has.have been told two different block vin locations,one was on the front of the head,other was back by where bell housing hooks up.as for the intake its got edelbrock on it,not a whole lot else like some others i've seen.
The number on the back by the bell housing is the number to determine what the block is. There may be a number between the carb and distributor on the intake to tell you what the intake is. If not you'll have to look at the shape of the intake specifically the area directly under under the carb. Where the carb bolt to the intake and runs down into the runners. If it is square it could be Performer RPM. If there is a gap under that area it could be a Victor Jr. or an RPM Airgap. If it is not squared off then it is more than likely a Performer.
83C10SWB
Hello all, new user to the board, i had the q-jet on the old 305 in my 83, i gave it to a buddy. I now have a Holly intake with a 600 CFM electric choke, as far as tuning, it's pretty simple to lean out the 2 banks evenly and richen the mixture till it sounds good. Not to mention it does pretty good for a $250 dollar investment.
thanks for the good info everybody.when i get some time,i'll figure out what i got.also post some pics if i can figure out how.i got a new problem with radiator,it needs replaced and i'm going to have to reroute trans cooler lines to other side of radiator,as this truck used to be a 5.7 diesel i just learned. by that ,and the fact it has hydo boost brakes instead of vacum assist.now some mysteries are begining to make sense.but hey..thats why i bought it.something to play around with.
Right turn Clyde
Quadrajets are Spreadbore (front mounting closer together and the rear farther apart. Edelbrock performer Carbs and Holleys are Sqaure bore (all the mounting points are same distance apart).
Anyway to post a picture of the engine?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#13 |
i'm gonna try on sunday,i gotta work 12 hour shifts till then.after that i'll get some shots of it.
#14 |
Please identify the carb and manifold i know that its a double pump holley but want to know what size and model of the manifold. Also where are the VIN ID # on an 87 and up 350 camaro engine.
#15 |
I believe it is a vacuum secondary, not a double pumper. It appears to be a dual feed but if you notice the black circular piece with four bolts in the right rear of the pic it appears to be the vacuum diaphram. As for the intake it a little hard to tell but if I had to guess it may be the Performer.
#16 |
Insert Witty Text Here
With those centerbolt valve covers, you engine is an '87 or newer. Well, at least the heads are.
![]() Slonaker |
#17 |
yeah i'm trying to get to all the block vin's.the one back by the drivers side bell housing flange says. 57lgsgi.which ,if i have them correct.should be a 350.the numbers on the pad on passenger side behind alternator are vh311954. which i think means built march 11 of 95 i don't know what others mean?i think theres another group of vin #'s back side of passenger side head.i was told its some late model camaro motor.they must of altered it for a carb.i just wanna find out what i'm buying parts for.
#18 |
A.K.A- Crummy
Holley Street Avenger. Or Demon. Sort of like badone07 not a fan of the Edelbrock. A good Q-jet is getting hard to find.
2003 Silverado Z71 Are fishermen all liars? |
Thread Tools | |
Display Modes | |
