Timing Chain Slop Question
While fixing an oil leak on the timing chain cover, I noticed my timing chain has quite a bit of play. You can easily move it left and right with your finger. Is it normal to have some timing chain play or should you not be able to move it much? Thanks very much for any replies.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
its worn out. spend the money and buy a good double roller chain and it wont stretch out like that. edelbrock chains are great and not priced bad either
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Or, Cloyes.Don`t let it go.If it jumps,you`ll end up with bent pushrods or,worse yet,bent valves.
yeah what they said /i too vote cloyes
what they said is VERY IMPORTANT and your truck will run much better.
The way to check for timing chain stretch (normally) is to check the timing of #1 and #6 cylinders. More than 6* difference is not good for normal driving. More than 3* difference is not good for high RPM speeds.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
20' Daredevil (Ret)
![]() Join Date: May 2003
What they said
Good point Stocker, I'd even add go one step further and adjust the valves while my hands are dirty.
68cst_ss490
Id replace it as everyone has said. But go with a gear drive instead.....more accurate timing plus very cool sounding......see 2 good reasons to change it
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
though i personally run a gear drive they do alot more harmonics into the crankshaft/valvetrain. a good double roller is fine especailly in a stock motor
![]() Join Date: Aug 2004
You're already in there, replace it. It will be a PITA to do it later.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Thread Tools | |
Display Modes | |
