Old 10-01-2005, 01:48 AM   #1
hewl35
Engine Swap Electric Problem
I've got a 70 C-10 with a transplanted 454 from a 76. The 454 starter has only one wire to the solenoid not two like the other starter had. I threw a battery in and the motor didn't crank but I have good lights, etc so I'm sure the grounds are good. What do I need to do to the wiring harness to get the motor to crank? I'm sure it something simple.
Jeff
hewl35 is offline   Reply With Quote
Old 10-01-2005, 01:56 AM   #2
krue
Designated A-hole!
krue's Avatar
The original wiring had one wire from the ignition switch (purple I think) and one going to the coil. The points ignition needs 12v to start but only runs on 9v to run (runs thru a resistor wire). The HEI you should have on the BB needs 12v all the time (I ran mine from the fuse block IGN UNFUSED) and the starter only needs the wire from the ignition switch.
I hope that made sense.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-01-2005, 05:55 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Make sure the purple wire is on the S terminal on your starter. if you are running an HEI coil, then delete the yellow wire that was on the starter, and then up top, also delete the cloth overed coil wire. This is a resistance wire that will knock the voltage down. Your HEI will need a full 13 volts. Simply run a wire from the ignition unfused plug on the fuse box, and run it out to the HEI's BATT terminal.
Thread Tools
Display Modes
