Old 07-05-2002, 12:09 PM   #1
DHregdovic
Originally Long or Short Water Pump?
Did the 67-72's come with a long nose water pump or short? Is there a difference in 2 or 4 wheel drive?
I'm yanking the old 6-250 and dropping in a SBC in front of the 4-speed. The 350 I'm putting in has a short one on it and I need to get all other accessory mounting (alt, pwr steer). I was going to go to the boneyard and find a donor SBC but though you guys could give some insight as to what I should look for to achieve ease of installation.
I was thinking if I were to put it in the 6-250 mounting location and got a 4x4 shroud - would I want long or short. I'm open to other ideas/suggestions. I'm not really worried about stock but rather fit/function...
67 LWB GMC
250 inline w/4spd manual
Disc/power brake conversion
DHregdovic is offline   Reply With Quote
Old 07-05-2002, 12:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Originally, they came with short pumps. However, I believe it's been said on here that if you install in the inline position, the long pump works and tucks the fan into the shroud.
Old 07-05-2002, 02:02 PM   #3
mikep
Used to have a truck
mikep's Avatar
I use a long pump with big block engine mounts and a big block shroud. Everything fits like a glove. I dont know if the 6 cylinder mounts put the transmission in the same place though.
No truck :-(
mikep is offline   Reply With Quote
Old 07-06-2002, 05:57 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
are more holes in frame rails for tranny to move forward too, there are more holes for any combination basically,
mikep, how'd you get 3.73 dana 60 under that 68 C20 ???
Fast68Chevy is offline   Reply With Quote
Old 07-06-2002, 06:12 PM   #5
tom hand
CCRider
tom hand's Avatar
If you put a v-8 in the 6 posistion, the short pump will work with the 4x4 fan shroud and the long pump will work with the 2x4 shroud. Good luck.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-08-2002, 07:32 AM   #6
Ed ke6bnl
long and short of it the water pump
If I were to change out the water pump from short to long to help get the fan closer to the fan shroud will I need to do something with the pulleys and there alignmen???? Thanks Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 07-08-2002, 11:16 AM   #7
6869704X4
If you get lucky at the bone yard(unlike me) you might find an engine with all the pulleys and brackets you need. Get everything.
I changed to a long pump because a bolt for the alternator bracket busted off in the head and I couldnt get it out cleanly. Had to splice alternator wires to get to the other side of the motor. Ive got a unique belt setup because I was scrounging stuff here and there. Got a pic if you want.
Cant help you with the fan stuff, I went electric.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 07-08-2002, 01:40 PM   #8
Desert Rat
Desert Rat's Avatar
If you need correct brackets and pulleys for short pump let me know.I also have long pump available.all original no repoduction junk.email me if interested gmcrat427@yahoo.com
Desert Rat is offline   Reply With Quote
Thread Tools
Display Modes
