Old 10-03-2005, 06:44 PM   #1
chevybill
chevybill's Avatar
Talking Hyd. clutch setup what all is needed?
Hey everybody, I finally have a late model 5 speed manual for my 70 c 10 with a vortec engine. What parts will I need to locate or modify for this conversion? Any ideas on a crossmember? Will I need something special for the engine and tranny since the engine came with an automatic originally?
The tranny is coming from behind a 4.3 V-6. How will I connect my clutch pedal to the hyd. clutch?
Where could I check on ratios for this tranny? It is out of a 99 or 2000 truck.
What am I going to need for the speedometer connection?
any input is appreciated
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 10-03-2005, 08:52 PM   #2
Blue_71
Bloo
Blue_71's Avatar
yes, you will need a manual flywheel, and a pilot bushing that goes in the back of the crank... you can also get pilot bearings, but i prefer the bushings
you will have to have a rod to go from the master cylinder, to the pedal arm... then you will have to drill a hole into your pedal arm and use a brake M/C rod bolt to bolt the rod to the arm
LOCATE:
clutch master cylinder
clutch slave cylinder
section of metal tubing with bubble flares
tubing bender
clutch m/c rod
clutch pedal arm
flywheel
clutch/pressure plate
pilot bushing
clutch fork
MODIFY:
make hole in firewall for clutch m/c
bend tubing to go from master to slave cylinder
make hole in clutch arm for rod to hook to
thats all i know for sure
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 10-03-2005, 09:01 PM   #3
chevybill
chevybill's Avatar
thanks for the direct response.
my truck is originally a 3 speed manual and i am hoping that i could
use my original pedal assembly if possible.
you gave a great response, i appreciate that very much.
Old 10-03-2005, 09:06 PM   #4
Blue_71
Bloo
Blue_71's Avatar
your original pedal assembly will work if you drill the hole into the clutch arm for the m/c rod.... the clutch/pressure plate, and clutch fork will be different from hydralic to manual clutch though
Old 10-03-2005, 10:33 PM   #5
Canadian72GMC
Where are you located, I just took a 5 speed out of mine.
Canadian72GMC is offline   Reply With Quote
Old 10-04-2005, 08:15 AM   #6
chevybill
chevybill's Avatar
I am in northern mississippi about 2 hours from memphis tn.
Thread Tools
Display Modes
