10-07-2005, 01:25 PM | #1 |
Speedwarning + vacuum dash complete $400 USD delivers to North America
Here is a speedwarning cluster for the 67-72 era...complete with buzzer...wiring, cable knob nut and has a vacuum gauge also. Delivered from Canada near Winnipeg will be $400 USD. May seperate if wanted to lower costs some...as in I can make it a vacuum dash or a speedwarning dash.
PM, post or the email link I think works in my profile.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 10-07-2005 at 01:47 PM. |
10-12-2005, 01:07 PM | #2 |
ttt
10-12-2005, 03:16 PM | #3 |
How much for just the speed warning?
10-12-2005, 04:41 PM | #4 |
$300 and I'll split the actual shipping. Insurance your option at $1 per hundred..I'll pay the first hundred insurance.
10-13-2005, 09:51 AM | #5 |
Would it be possible to covert to tach as well?If so,what would it take?I have the pans for a tach dash w/guage cluster and the right lense for tach`n`vacuum.I`d have to look but,Is the cut-out there for the vacuum guage in all other guage pans?I guess as far as the printed circuit goes,I`d have to wire the tach lights in from the headlight switch and use your circuit.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-13-2005 at 09:53 AM. |
10-13-2005, 10:14 AM | #6 |
Anyway you want it I can build it. I can do it..tach vac 400. tach vac speedwarning 800, tach speedwarning 700
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 10-13-2005 at 10:16 AM. |
10-13-2005, 05:29 PM | #7 |
The ijner pans for any gauge package have recessed depressions which mold to the gauge so you dont see around the whole into the dash ..without using the proper inner panel you are just cutting a hole...and you;ll know its not right. The back plate for the tach. you could pretty much make from a normal rear plate.....won't be a clean piece but you could get by.
Now if your taking speewarning dash you need to have the proper stud for connecting the speewarning wiring to the rar plate. Pretty much what I'm saying is I got it built...or can build it anyway anyone likes. If your attempting to piece one together you'll figure it probably wasn't worth what you could buy a correct complete one for. But if you get stuff cheap enough..maybe you can. |
10-13-2005, 07:22 PM | #8 |
What I was thinking is I`d buy your speed warning/vacuum dash.Then,if feasible,I`d use the parts I already have to ad a tach.I have the lense for a tach/vac dash,but not the back panels and printed circuit from a tach/vac.Just those pieces for a tach dash.I think I can get away with adding the tach I have w/o using a printed circuit.So,the only thing I`m not sure of is the rear panels since the dash you have has no tach and the panels I have didn`t have a vacuum guage.I just need the pans and printed circuit to do it 100% correct.I would get those if I can`t make my tach/no vac pans work.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-13-2005 at 07:29 PM. |
10-13-2005, 09:43 PM | #9 |
From what I figure from your thread replies..you probably need just the complete spreedwarning and the vacuum gauge..is that right? You dont need the vacuum lens cause you have a tach vacuum lens.
Do you have the correct inner plate for the tach dash and the 4 lower gauges. That seems to be something you have yet to mention. Really if you want a speedwarning tach vacuum dash..lets see..less the tach, but with a vacuum gauge and less the lens itself but with proper inner and rear plate for a tach and speedwarning...well its possible. Use a proper printed circuit....I have that too. Perhaps emailing is best. Check your PM |
10-14-2005, 09:23 AM | #10 |
Yes,I have the tach/guage back panels.You have a printed circuit for a full-tilt dash:tach,guages inluding vacuum,and speedwarning?
10-15-2005, 12:14 AM | #11 |
Well I guess you just have to tell it again and again.
I can build or should I say I have it built anyway you like it. top to bottom tach dash speedwarning dash tach vacuum dash speedwarning vacuum dash speedwarning tach vacuum dash I dont have any extra printed circuits...only complete dashes with all decent parts. Whats your poison?
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
10-15-2005, 09:30 AM | #12 |
If I had the money,I`d jump on that "full-tilt" one on the bottom.(drooling)
10-26-2005, 06:59 AM | #13 |
Re: Speewarning + vacuum dash complete $400 USD delivers to North America
I can sell the vacuum cluster alone for $100 without the speedwarning if the the thread posters on vaucuum dashes might be interested.
10-26-2005, 04:02 PM | #14 |
Do you have a Vacuum gauge you would like to sell or trade?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
10-26-2005, 09:58 PM | #15 |
It's worth more with the lens and a cluster...if you just want the gauge...your choice..same price though.
11-01-2005, 11:33 PM | #16 |
do you have a inner dash part to hold a tach vac, and possibly a 3/4 ton front axle for a 71 / 72
1970 Longhorn, factory air & Cruise,Tach vac 1970 C 20 3/4 4x4 350 with turbo 350 auto, |
11-02-2005, 01:01 AM | #17 |
I've sold most of the parts to make dashes ... for now.
I only have complete ones now..I can make anything out of what you see above ..but to just sell the inner plate would render a complete dash unusable and really not have nearly the value....Byrd just bought a couple dashes for parts off the board..maybe ask him in a PM. Out of whats pictured above I could make 2 tach vac complete..if you want complete...well I can do that. The middle one of the 5 pictured is tach vac already. And is it just the axles your want or a whole axle assembly.....hub to hub. I have an inner axle or two for spares.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 11-02-2005 at 01:12 AM. |
11-04-2005, 06:40 PM | #18 |
Still for sale.
11-06-2005, 09:10 PM | #19 |
Re: Speedwarning + vacuum dash complete $400 USD delivers to North America
I would like the complete '71 dash with speedwarning + vacuum dash with Tach if is complete and working? Shipped to 95431 Will you except a US Postal money order?
Thanks MK
Dan |
11-07-2005, 12:01 AM | #20 |
Yah sure International Postal moneys...Ill say it again International Postal Money Orders are fine. I believe it ALL WORKS. I could install it if you would like first, and make 100% sure. The tachs fine, buzzer works fine too those I tested.
Pm me your email and I'll send you my mailing address. Last edited by Rod; 11-07-2005 at 12:02 AM. |
11-07-2005, 11:43 AM | #21 |
Anyone of these is still for sale.
11-08-2005, 01:41 AM | #22 |
Closer pics of the speedwarning and vacuum with tach
11-21-2005, 02:23 PM | #23 |
Christmas is coming..buy your own gift to yourself.
11-21-2005, 02:45 PM | #24 |
computer illiterate
ill trade yah 2 tach dashes and a half dozen non tach guage dashes for the tach,vac,speedwarning dash?
72 2wd blazer 72 swb 4x4 |
11-21-2005, 03:39 PM | #25 |
Sorry...not interested in that type trade right now.
Thread Tools | |
Display Modes | |
