Old 07-06-2002, 11:45 AM   #1
mikegi
is this diff. posi???
how do i tell,glove box says so,vin matches glove box.diff cover bolts were hard to come off,like they were never off in 30 years
is'nt both tires suppose to spin at the same time when jacked in the air?? this one spins 1 wheel at a time.
Springvale,Maine
71 3/4 GMC lwb
mikegi is offline   Reply With Quote
Old 07-06-2002, 11:58 AM   #2
Sierra
That is an open differential. A previous owner could have swapped out the entire rearend assembly. Sorry.
Sierra is offline   Reply With Quote
Old 07-06-2002, 12:00 PM   #3
Blue_71
Bloo
Blue_71's Avatar
if im nto mistaken, one wheel at a time means worn out posi.. posi both wheels should turn the same direction, and non they should spin opposite directions with the rear jacked up. i dont know what posis look like though so i dont know by the pic
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-06-2002, 01:21 PM   #4
mikegi
i thought maybe someone swapped rears!!! Dam
Springvale,Maine
71 3/4 GMC lwb
Old 07-06-2002, 02:29 PM   #5
Super Chevy
Super Chevy's Avatar
looks like an open to me
Super Chevy is offline   Reply With Quote
Old 07-06-2002, 02:45 PM   #6
Fast68Chevy
Fast68Chevy's Avatar
the ultimate way to test for limited slip or locker unit short of burning rubber on gravel or pavement is to have someone hold a wheel in place and you turn the pinion yoke clockwise and if the assistant cant keep the wheel from turning then its a limited slip/locker, these units provide power to the wheel WITH most traction and not the least like in open diffs,
also with both wheels hanging, BOTH wheels will spin same directiona nd same speed if you turn the yoke, if you have limited or locker
the pic above that you provide depicts a std open diff, not the lack of springs and clutch plate tabs on RH side in the unti
good luck
Fast68Chevy is offline   Reply With Quote
Old 07-07-2002, 12:44 AM   #7
Rod
Factory Posi looks like this type.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-07-2002, 07:12 AM   #8
mikegi
thanks rod.pics help alot
Springvale,Maine
71 3/4 GMC lwb
Thread Tools
Display Modes
