72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
Since Im really not an afficianado for these years, for a Mark IV 454 version engine, are the frame stands different on these chassis's?
I assume that the motor mount to the frame stand is 454 only!? I have smog, although I just located a partial smog equipment system, I might consider going to a 454 with all the smog... Thoughts on the frame stands/motor mounts? ![]()
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
Web Wheeler
454 and smallblock frame stands are the same. You use a different set of holes on them depending on which rubber mounts you are using.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
#3 | |
yeller
All the V8's can use the same stands and holes in the stand as well as the same mounts...the six cyliner engines use the different mounting holes in the stand. The holes on the stands are labeled "6" and "8". I went from a 350 to a 454 and did exactly this. Other members on here have done this as well. On a side note, according to GM the stands for a 454 and 350 have different part numbers...but I have no clue to what the actual difference is...and I didn't want to spend the $120 for the set to find out.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Could the 454 GM stands have support gussets on the backsides to support the heavier demand?
My 69 Camaro GM 396 frame stands as well as SS350 frame stands in that year added an under support gusset to strengthen the stand overall..
#5 | |
Web Wheeler
My '79 GM Service Manual has pictures of the mounts together with the frame stands and which holes ar used for each. I suppose the stands could be different part numbers... they are similar enough than GM used the same drawing for both mount combinations.
Thread Tools | |
Display Modes | |
