Old 10-13-2005, 11:32 PM   #1
65ChevyC20
harmonic balancer
Just ran into a situation on my 65 Chevy C20 w/ 283. I needed to remove my old balancer due to the rubber deteriorating and the pulleys wobbling. I went to remove the bolt that holds the dampener on and there was no bolt. I used the puller to get the old balancer off, after I had the old one off I checked to see if there were any threads inside of the crankshaft where a bolt once existed, there were no threads.
Ths leads to a few questions,
1) did this motor have a press on balancer?? and where do
get the tool to press the new balancer on??
2) would you recommend drilling/tapping the end of the crank to use a retention bolt?? If I drill this hole this would aid me in putting on my new dampener??
any help would be greatly appreciated
Aaron
65ChevyC20 is offline   Reply With Quote
Old 10-14-2005, 03:58 AM   #2
speedking
My '62 283 didn't have a balancer bolt. And the 355 I installed to replace the 283 doesn't either. I don't think it's that critical with the early style balancer. I used a rubber freeze plug that just fits the inside diameter of the hole in the early balancer,and instead of the regular nut,he used a 3 bar spinner style air cleaner wing nut to fill the balancer hole. Looked really cool,and isn't heavy enough to mess up the balance. Just be sure you can tighten it enough that it can't wiggle loose. It may require some tinkering to get it right.
Speed
-57 GMC 1/2 ton longbed,Pont. 400,4 speed
-62 Chevy 1 ton duallie,Chevy 355,4 speed
-66 Pontiac Catalina 2 dr. hardtop,389,T-400
-81 Ford Fairmont wgn.,2.3,4 speed
-68 Triumph TR6-R 'cycle,various mods
-66 C-60's back
-there's probably others...
speedking is offline   Reply With Quote
Old 10-14-2005, 10:48 PM   #3
64fleetside
My 230 has no bolt either, I just swapped dampners a couple weeks back. I put the dampner in the oven @200* for about 30 mins, then used a heavy mallet to push it on. With the temp diff it almost goes all the way by hand, just a tap or two & it was fully seated. Brian
64fleetside is offline   Reply With Quote
Old 10-14-2005, 11:23 PM   #4
65ChevyC20
thanks
Brian, thanks, that is a great idea, I have heard of that being done before but didn't even think of using and oven in this case. I will try it tomorrow
Old 10-15-2005, 10:09 AM   #5
62 short step
62 short step's Avatar
balancer
My 62 283 balancer come off on the road while driving. I was told that i could drill and tap it,i did that and solved the problem.
62 short step is offline   Reply With Quote
Thread Tools
Display Modes
