Old 10-18-2005, 02:50 PM   #1
sammytued
57 chevy 3100
I wanted to know if the frames are the same on a 1955 100 series and a 1957 3100 series.
sammytued is offline   Reply With Quote
Old 10-18-2005, 08:31 PM   #2
qksilver
Re: 57 chevy 3100
You are talking about an early 55, I can't remember the name of the series. If yes, the early 55 and the 57 are different.
Steve
qksilver is offline   Reply With Quote
Old 10-20-2005, 11:18 PM   #3
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Re: 57 chevy 3100
Welcome to the boards sammytued.
If you ment the '55 second series "3100" being the same as the 1957 3100, the differences are very minor (I cant find my assembly manual).
These should swap with little to no modifications.
The '55 first series is a completely different animal.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 10-26-2005, 08:52 PM   #4
ChargerBill
ChargerBill's Avatar
Re: 57 chevy 3100
'55 to '57 second series frames will all interchange. '58 - '59 frames are longer, but will still work as a '55 - '57 frame if you lop a few inches off the front of the frame. '55 first series frames will not work for any second series '55 - '59 pickup.
1956 Chevy Custom Cab
1978 Chevy K5 Blazer
2002 4X4 Silverado
1969 Dodge Charger
1968 Dodge Charger
ChargerBill is offline   Reply With Quote
Old 10-27-2005, 01:53 PM   #5
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
Smile Re: 57 chevy 3100
No, they are not the same. Within the TF series (late '55-'59), the primary difference between GMC and Chevrolet frames is the front crossmember. Otherwise they are nearly identical and bodywork from either a GMC or a Chevy will bolt to either chassis (may need to obtain/remove the Chevrolet radiator/front fender support frame bracket)...
PHOTO HERE
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
Thread Tools
Display Modes
