Old 07-07-2002, 05:41 PM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Question Automatic Transmission Questions
I was wondering if anyone knows if a 400 Turbo bolts up the same as a 350. And are the overall lengths the same? I don't want to have to have my driveshaft cut. Also which length tailshaft long or short came in a truck? And why are the 400 Turbos a stronger transmission than the 350's? Please help!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 07-07-2002, 05:50 PM   #2
68 with 350 TPI
68 with 350 TPI's Avatar
The 350/400 will interchange on the bolt up just fine.
That is so long as it is a Chevy pattern and not a BOP (buick,pontaic,olds) .
Also make sure if it is a long or short tailshaft to have an exact fit.
The 400 is stronger mainly because of the drum/sprag has more holding power.
The 350's drum is smaller and with less rollers in the sprag.
But the 400 will use a little more HP to run. about 10-25 hp depending on what is done to it, and wear and tear.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-07-2002, 11:01 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
long tail shaft if you have 2 wheel drive...
the drive shaft is different for a 400...
check out...
[url]http://my.en.com/~thall/olds/oftrn.htm[url/]
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-08-2002, 12:07 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The 400 has a longer overall length too. You'll have to move your cross member back, shorten your shaft, and get a new yolk. Over an inch longer than the TH350 short shaft that was origianl in our trucks.
I'd just find a TH350 IMO.
Old 07-08-2002, 11:11 AM   #5
Firefighter
Smile
Thanks Guys!!!
Yellville, Ar. USA
Thread Tools
Display Modes
