Old 07-07-2002, 06:45 PM   #1
19mike69
powersteering pump
i had a question about my p/s pump on my 69....i noticed how it has rubbed the inside of my alternator belt something terrible....i needed to replace the alt belt so when i loosened up the p/s pump it was all the way loose but the belt was still too tight to get it off ,and since the pump needed to be replaced too i went ahead and took it off...but you could clearly see where the alt belt was rubbing the p/s pump,does anyone know why?it is factory p/s....could the pump have been shimmed out away from the block for some reason?....any help will be appreciated,thanks
19mike69 is offline   Reply With Quote
Old 07-07-2002, 08:49 PM   #2
racedvl
racedvl's Avatar
Hhhhmmm..... is there a way you could post a pic?
racedvl is offline   Reply With Quote
Old 07-07-2002, 09:00 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If it is the factory set up, look at the lower/rear pump mount...it should go back to the driver's side motor mount.
I'll bet it is broken.
Old 07-08-2002, 04:33 PM   #4
19mike69
thanks longhorn...ill be sure and check that out
Thread Tools
Display Modes
