10-20-2005, 02:08 AM | #1 |
351 V6 questions
I'm trying to talk myself into or out of buying a 68 GMC w/ a 351 V6/Th350.
Pros & cons from those who own or have owned this motor? Are there any upgrades, re-buildable parts around? I'm a bit worried because it has about 170K showing and I'm not sure how much life is left in this engine. |
10-20-2005, 07:27 AM | #2 |
Re: 351 V6 questions
I looked into buying one of these motors, there is a post somewhere that I will try to find....there doesn't seem to be much in the way of upgrades, and parts seemed difficult to located (at least when I ended up talking myself out of buying one). From what I gathered it boils down to what you are going to use the truck for, if you need a tow truck, stump puller, and something to haul stuff around in.....but just around town, its a good setup, if you want a highway cruiser at all.....3.08 gears (from what I am told) is your only hope as these engines don't like High RPMS.
http://www.6066gmcguy.org/ <---- this is the best site to find information about these motors. hope that helps |
10-20-2005, 07:35 AM | #3 |
These are low rpm high torque motors for pure "truck" type usage and have no appreciatable value especially with high miles. Forget about upgrades--. If this is a key part of your decision, if it runs and that is all you need--that's fine but don't buy it with great expectations. These trucks are primarly valued for the quality of the sheet metal, ease of repair and low cost of replacement parts. Buy accordingly--Huck
10-20-2005, 09:26 AM | #4 |
I'd buy it.............Not many are left with the V-6 still under the hood, and the 351 is EXTRA hard to find anymore. As long as you keep the block in one piece it will run a long, long time...........Most parts you can still get other than items like crank, block, cam, and heads, big stuff in other words.
My '69 GMC was a township truck, in other words who knows how many miles the 305 V-6 under the hood has on it, but it still is running hard. IMO, GMC's big blocks were some of the best engines ever put in a truck, they pull like h*ll and you can't kill them on a hill, they will lug like crazy until the cows come home. I use my truck for work, and I wouldn't trade my V-6 powered truck for anything else!
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
10-20-2005, 11:11 AM | #5 |
I had plans to use it as a parts runner until I finish an un-planned resto of my K20. You know... the brake job turned into a axle swap, power brake up gread and gee those motor mounts look tired. Why not pull the 283 and plant a 350, time to get rid of the rockwell transfer, so look for a new tranny, ect ect...
In the mean time I need to haul wood for winter, carry the scrap off, pick up a couch. The common everday uses we all have. Thanks for the input and the link. |
10-20-2005, 01:03 PM | #6 |
I would be very interested in purchasing the heads, intake and exhaust manifolds off that 351. They are a good engine, but love the gas. If that is the original transmission, then it should be a TH400 or 2sp power glide. If it has p/s or AC those parts will sell. Sold an AC bracket for $200. The auto to 351 adapter is also worth some money, had a guy offer $250 for mine. Other parts on there are worth selling too.
Let me know.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX Last edited by Erl; 10-20-2005 at 01:04 PM. |
10-21-2005, 10:43 AM | #7 |
They were/are very good motors.They use as much fuel as a V8.The 351 is a 409 minus 2cyls.The 302 is the 348.Parts are rare but available for those V8s and nobody runs away from those.You`llprobably never need a crank and,I believe the rest is the same internally.It wouldn`t make the best daily driver(same as all these trucks)these days,but a cool run around mill.
10-21-2005, 12:11 PM | #8 |
Cantankerous Geezer
I drove a bunch of the GMC V6 trucks when they were new. They were popular with the bean-counters that ran businesses. Most guys that drove them hated them, since you couldn't make one go fast and last.
GMC used a high nickel alloy for the block. As long as it isn't using oil and is properly cared for, it could easily go another 170K miles. The 351 is the best engine of the series. It will make you a good hauler, just don't get in a hurry. The crank has huge counterbalances, and does not like to be revved. GMC set the redline around 3,500 rpm, but running at high rpm for extended times will shorten the life in a hurry. Best to keep the rpm under 2,500 for the highway.
Fred There is no such thing as too much cam...just not enough engine. |
10-21-2005, 04:30 PM | #9 | |
10-21-2005, 04:47 PM | #10 |
Watch out for your cornhole !
70rs/ss, I don't follow the 348 deal. What does it have in common with the 351 V6?
10-21-2005, 04:50 PM | #11 | |
351 is a 348 with two cylinders whacked off. So they are pretty much the same. |
10-21-2005, 04:54 PM | #12 |
No way. You can't remove cylinders from a 348 and make it BIGGER to a 351. Not possible.
It would have to be smaller than a 348 if you chopped off 25 percent of the cylinders.
10-21-2005, 05:21 PM | #13 |
Saving 1 truck at a time!
Hmmmmm, a 409 with two missing cylinders would be a 306.75, V-6. I have had two of them and don't like them just because they are DIFFERENT...LOL! Ben, how about a '68 50th Anniversary C10 with a six...runs and looks pretty...$500!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
10-21-2005, 08:24 PM | #14 |
Your holding out on me... where is it?
10-21-2005, 08:30 PM | #15 |
Call me.
10-22-2005, 09:44 AM | #16 | |
10-22-2005, 10:02 AM | #17 |
They are strokers as in torquey/lower rpm.The longer stroke figures in to the displacement as well as bore.I don`t how it all adds up but I was always told the 351 V6 was a whacked 409/302 a whacked 348.Does not compute.So,it must be a 302 is a 6cyl 409(409-25%=302).Either way,they are the same tougher than nails overbuilt older technology(and slower times)motor.Like the later V6s being 3/4 of a small block V8(5.7-25%=4.3).
70rs/ss,I think your GMC might have had a Pontiac motor in it.That`s what they were doing back in the 50s.Maybe not by`59.
10-23-2005, 01:05 AM | #18 |
I have decided to pass on the deal. If anyone is interested just type in 68 GMC into Seattle's craigslist. It's the blue one for $950...... so many trucks...so little time! Thanks everyone for all the imput & info.
PS: I stand corrected, the truck has 130K miles on it. |
10-23-2005, 06:51 AM | #19 |
It would seem a better deal has come your way.I guess that`s why you`re not stllookin.
10-23-2005, 08:20 AM | #20 |
Where's my beer?
I'd love to ride in one of these trucks with a 351 V6 after hearing all the discussion on this site about them. I'd like to see how they pull.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
10-23-2005, 08:32 AM | #21 | |
03-22-2006, 09:15 PM | #22 |
Aluminum slot wheels rule...
Guys, V6 GMC's are completely different from 348-409 Chevys, GMC v6's were made in 305,351,379,401,432 and 478 inch engines. Plus there was a 637 V8 made from the V6's, and a 702 V12 which was 2 351's together. Read for yourself.
www.6066gmcguy.org Last edited by JAKES 68GMC; 03-22-2006 at 09:16 PM. |
03-22-2006, 09:40 PM | #23 |
its all about the +6 inches
Jake is 100% right, there is nothing simalar between the W block motos (348 & 409) And the GMC V-6 motors. The spark plugs are on top of the heads by the intake instead of on the bottom by the exhaust, and in all reality, they are huge even compaired to a 409.
03-22-2006, 09:50 PM | #24 |
Even the oil pan drain plug is different!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
03-22-2006, 09:59 PM | #25 |
Yup. 1 1/8 inch drain plug on mine.
Thread Tools | |
Display Modes | |
