Car O'Holic
Ok, so I got the truck running today, and I backed up brakes worked fine even screeched a little, put it in drive to go around the block and after about brakeing twice bam peddle to the floor like I just lost pressure. so I turn it off and wait push the pedle and bam pressure, so I go to start it again drive hit the brakes about twice bam peddle to the floor.
What is going on? my truck is now on the side of a road ![]() |
Designated A-hole!
Re: No Brakes!
How much fluid in the master cylinder? Any visible leaks? Power or manual brakes? Will they pump up?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" Last edited by krue; 10-24-2005 at 08:56 PM. Reason: I reread the original post. |
![]() Join Date: Sep 2005
Re: No Brakes!
front disc brakes rear drums power brakes? i would check for leakings do an full visual check frist. check the wheel clyiders make sure they are not blown check the master cyliders i don't think its an adjustment problem or it would do it all the time. i would bleed the whole system you might have air in it
Black 72 Chevy
Re: No Brakes!
It sounds like your master cylinder is not working. When my master cylinder died, the brake pedal would drop to the ground. I had to pump the brake pedal a few times to get some pressure. Hope this helps.
#5 | |
Car O'Holic
Re: No Brakes!
thats what I am thinking I have power brakes, with drums all the way around, new brake hardware shoes and brake cylenders. There were no leaks around the wheels, but I think that my MC is going out, and the crappy thing is that the lines to the prop valve are soo close to being rounded off bc of the PO. ![]() |
Questionable
Re: No Brakes!
Vice grips
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#7 | |
Car O'Holic
Re: No Brakes!
Registered Cruiser
Re: No Brakes!
Does your parking brake work? Could you use to move the truck into the driveway?
I intend to live forever. So far, so good. |
#9 | |
Car O'Holic
Re: No Brakes!
Car O'Holic
Re: No Brakes!
Ok so quick question can/would it be safe to use a C-20 MC on a C-10 would it mess up the brake cylenders lines prop valve etc? I am going to get a new mc and brake lines from the MC to the Prop Valve today so I wanted to know before I go
Re: No Brakes!
NOPE just get the rpop vavle with oit
Re: No Brakes!
yea sounds like the master cylinder, my g-pas truck did that once and all u can do is pump it for pressure
Thread Tools | |
Display Modes | |
