Old 07-08-2002, 03:44 AM   #1
Blue_71
Bloo
Blue_71's Avatar
speedo reading difference?
im changing my truck from a 3 speed manual to a 4 speed manual (SM465) and changing the rear gears to a 3:07 posi (beleive its a 3:73 now) about hwo off will my speedometer be?
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-08-2002, 07:27 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
enough. heh heh heh
Old 07-08-2002, 07:46 AM   #3
mrein3
mrein3's Avatar
If you are putting the tranny in your 4x4 and you don't change rear end gears it won't be off. On 4x4s the speedo cable goes in the transfer case.
I'll guess since you are going from a 3.73 to a 3.07 you'll be off by 20% at every speed. There is very close to a 10% difference between all the factory offered rear end gears. 10% more than a 3.73 gets you to 4.10. 20% from a 3.73 gets you close to 3.07. With no torque converter slip in a straight stick it is just simple math.
I believe the NP205s speedo output was geared for a 3.73 rear end. This is based on the fact that I took a 3-speed manual/NP205 out and replaced it with a Th350/NP205. The new 205 came out of a truck with 3.07 gears. My truck has 3.73s. The new 205 had an adapter attached to the speedo output on it. When I installed the new 205 I left the adapter off and the speedo works within one or two mph of my GPS which is what it did before the swap.
BTW a GPS that can show speed over ground in mph is a GREAT way to check your speedo.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-08-2002, 04:41 PM   #4
Blue_71
Bloo
Blue_71's Avatar
thats going in the 71 1/2 ton 2wd. the 4x4 already has a SM465 and NP205, with 4:11 rear gears.
1989 Chevy K2500
Thread Tools
Display Modes
