Old 11-08-2005, 09:03 PM   #1
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Question Dana 60 posi/lockers
What are you guys using in your Dana 60 to eliminate the one wheel squeal? I know you can get Detroits for them but $600 is a bit out of the budget. I don't think welding the spiders is a good thing to do on a daily driver so i'm trying to figure out a different method. Thanks.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 11-08-2005, 11:19 PM   #2
leadfoot067
horsepower junkie
Re: Dana 60 posi/lockers
spicer still makes either the power lock or trac lock for the 60....ur cheepest place would be a bigger 4x4 outlet place...and/or used.....just make sure the axle spline count is the same as what you have...
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
Old 11-08-2005, 11:21 PM   #3
phantom dually
Project92 SWB stepside
phantom dually's Avatar
My D60 still has the factory trac lock. There are said to be great units. I would suggest Eaton for a replacment. Try Ebay.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-09-2005, 02:00 AM   #4
1969 GMC
1969 GMC's Avatar
I don't know if you can still get new trak-locks, but the new power-lock are almost as expensive as the Detroits. there are also lock-rights, which are a lunchbox locker.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-09-2005, 12:03 PM   #5
Rod
Yah the maximum traction power-lok option was available. I have one here.
Rod is offline   Reply With Quote
Thread Tools
Display Modes
