Old 11-12-2005, 08:55 PM   #1
truckdude239
truckdude239's Avatar
carrier bearing question
okay i just reinstalled another transmission in my truck finally got it done today was adjusting every thing got going though the gears and i started to smell something burning got undernoeth and the carrier bearing was burning it self up. took it off and took it back to the parts store and got another this one did the same thing expect it had larger coulds of smoke. am i doing something wrong?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-12-2005, 09:52 PM   #2
neonlarry
neonlarry's Avatar
Re: carrier bearing question
Well it sounds like your doing something wrong, either installing it wrong or buying from the wrong place. Describe what you did when taking the old one off and installing the new one.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-12-2005, 11:59 PM   #3
truckdude239
i pulled the metal shield off took drive shop to shop had old bearing pressed off . i then tokk the new one slid it on (with metal shield) and bolted the yoke on is it possible i bent the metal shield and its rubbing the rubber parts of the carrier bearing?
David fuller
2000 Tahoe 5.3l 378
Old 11-13-2005, 08:58 AM   #4
chops333
did you line everthing up like it was when you took it apart
chops333 is offline   Reply With Quote
Old 11-13-2005, 09:10 AM   #5
truckdude239
yes i marked the drive shaft the way it cam apart and installed new u joints
David fuller
2000 Tahoe 5.3l 378
Old 11-13-2005, 10:38 AM   #6
neonlarry
neonlarry's Avatar
It sounds right to me (the installation), maybe a bad bearing. The rubber should be there just for shock absorption.
Old 11-13-2005, 04:55 PM   #7
TP from Cntl PA
TP from Cntl PA's Avatar
I ditched those stupid metal shields when I replaced mine...........They looked like they were going to rub so I tossed them.
So far this year I've put in two carrier bearings..............Cummins is not fond of the stock '71 driveshaft/u-joints/carrier bearing...........I am getting a heavier duty setup made at the moment.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 11-13-2005, 08:40 PM   #8
Green Machine
Green Machine's Avatar
When you put in the driveshaft, install the hanger bolts loosely, then tighten rear u bolts on the joint on the rear end. Go back to the hanger bearing and insure that the metal part is centered on the rubber before tightening, also insire the the metal support is at a right angle to the drive shaft, may have to bend the mount on the frame to get it square.
If you tightened the hanger bearing down first and the attached the rear, you will likely pull the shaft into the hanger rubber and burn it up.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Thread Tools
Display Modes
