Old 11-15-2005, 02:54 PM   #1
jcarlar1
You Are Not Forgotten
jcarlar1's Avatar
Vintage Air install firewall pics
Hey people, I have just received my vintage air system and I am looking for pictures of shaved firewalls with this setup. I have seen quite a few of them on this site but can't seem to find them again. What I remember was a finished product with a neat metal finish, not with the plastic supplied by VA. Any & all help is greatly appreciated. A 72 chevy is the project.
If you don't know where you are going, any road will take you there!
jcarlar1 is offline   Reply With Quote
Old 11-15-2005, 04:46 PM   #2
jcarlar1
jcarlar1's Avatar
Re: Vintage Air install firewall pics
No one has any pics of finished firewall after VA a/c install???
Old 11-15-2005, 04:51 PM   #3
Joe67
67 is sold
Should be a good thread
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 11-15-2005, 05:25 PM   #4
dennislbrooks
dennislbrooks's Avatar
yea, will send a couple when I get home--however I do have Old Air
dennislbrooks is offline   Reply With Quote
Old 11-15-2005, 05:45 PM   #5
jcarlar1
jcarlar1's Avatar
Anything for ideas would be greatly appreciated
Old 11-15-2005, 06:33 PM   #6
mocwon
Keep On Truckin'
mocwon's Avatar
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 11-15-2005, 06:48 PM   #7
shifty
Questionable
shifty's Avatar
Link to FirstGen's install (can't tell you how many times I've posted this)
http://67-72chevytrucks.com/vboard/s...75#post1310375
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-15-2005, 07:08 PM   #8
dennislbrooks
This is Old Air in my 67.
Old 11-15-2005, 07:43 PM   #9
FormerMember
No AC installed yet, but you can see the shaving job I did on the firewall in this pic here, from Vtblazer's thread:
I cut out both of the non-ac holes with their support ribbing and welded in 16 guage sheet steel. I also did it for the fan duct hole.
I plan to run the hoses through the bottom of the cab instead of that spot in the FW.
FormerMember is offline   Reply With Quote
Old 11-15-2005, 08:55 PM   #10
jcarlar1
jcarlar1's Avatar
For Mocwon; In your picture you have the hookup I am interested in, is it a custom unit ,factory, or did you fabricate it?
Old 11-15-2005, 09:14 PM   #11
70c10swb
no brain no headache
70c10swb's Avatar
Is that what the two holes are for on the floor in the back?
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 11-15-2005, 09:28 PM   #12
Joe67
67 is sold
Any pics of the AC hoses running down as low as they can?
Old 11-15-2005, 09:51 PM   #13
FormerMember
Yes.
Old 11-15-2005, 11:22 PM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
Vintage Air Super Gen II. The hose connection bulkhead plate is also Vintage-Air. I plated the firewal to smooth it first.
Just Passin' Thru
Old 11-15-2005, 11:31 PM   #15
mocwon
Keep On Truckin'
mocwon's Avatar
Just Passin' Thru
Old 11-16-2005, 10:59 AM   #16
coolair
If you purchased the Sure-Fit system, it is designed as a bolt in kit with the lines running through the firewall plate. If you want a smooth firewall, a universal kit like mocwon is using OR modify your evaporator and install a coil with the lines running parallel to the firewall. Which option you choose will also depend on what control panel you want to use - OEM controls, you will need to have your SFK evaporator modified. Universal system would require the use of a VA universal control panel mounted into your dash.
Call Vintage Air if you have any questions - we can walk through you options with you. 1.800.862.6658
Mark
coolair is offline   Reply With Quote
Old 11-16-2005, 12:09 PM   #17
shifty
Questionable
shifty's Avatar
Yes.
Just for curiosity, did you shave anything inside the tranny hump/setback at all? Mine has a lip on it - right here:
http://satellitehead.com/images/68ch...lems%20008.jpg
I don't see that on yours ?
Old 11-16-2005, 01:28 PM   #18
FormerMember
Not yet. It's a low hump cab and I believe it has that set back.
Old 11-16-2005, 03:03 PM   #19
shifty
Questionable
shifty's Avatar
I am looking, I just don't see that lip on yours. I see the hump (or setback or whatever) but not the lip. It's eating me up what to do with mine
Old 11-16-2005, 03:40 PM   #20
cypress TX 72
Saving one 72 at a time!!
cypress TX 72's Avatar
Jcarlar1,
I will shoot some pis tonight, what I did was, Placed a thin paper sheet over the whole opening and traced it, then I cut it out of sheet metal and tacked in in place. I finished it with brass and sanded it smooth, for the hole that the line came through, I took a peice of 3" Iron pipe about 2.5" long and welded it in place and ran the lines through the front, I cut the holes out of the cap to let them go through.
It looks really good, but it is a lot of work, when I did this I had the cab off and on a stand, depending on what stage your in, this may not be an option.
It seems like the last time I talked to Mike at Vintage Air, when I ordered my system for my Chevelle, he said that they were working on some new blanks for this area. He said they were looking for someone to make some billit aluminum plates..But I don't know where that ended up.
I would call up there and see if they have anything, its worth the phone call before I would do all this fabricating.
TS
cypress TX 72 is offline   Reply With Quote
Old 11-16-2005, 05:57 PM   #21
FormerMember
It's there, just in gray primer atm.
Old 11-16-2005, 06:24 PM   #22
jcarlar1
jcarlar1's Avatar
TS looking forward to seeing your pics, I have a bare cab off the frame at the present. I called VA and the bulkhead adapters will not work with the sure-fit package I bought so they say. I don't mind the work if it looks good, thanks, John
Old 11-17-2005, 09:12 AM   #23
jcarlar1
jcarlar1's Avatar
Ttt
Thread Tools
Display Modes
