Old 07-10-2002, 09:27 PM   #1
69mychevy
yes i did post something
please help im workin on this right now
hey i jus got a truck and im tryin to find a hole threw the firewall from inside of the truck and i found the perfect one inside but it involves popping a rubber piece out of the outside of the firewall is there a reason everything has rubber is it a safety concern or is it for show?
69mychevy is offline   Reply With Quote
Old 07-10-2002, 09:37 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The rubber plugs in the body(firewall included) were usuallythere to keep water and fumes out.They can be removed but may allow hazardous fumes into your cab.If you are removing the plug to run wires or hoses thru the hole you will want to use a grommet to keep from wearing thru the hose/wire.I would suggest you find a grommet that fits tight to the hose/wire so that water or fumes can't get in.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-10-2002, 09:58 PM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
What he said and...It helps keep the engine/road noise out
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-10-2002, 10:11 PM   #4
nu2-72
Sometimes you can reuse the plug. Make a small hole for your wires to pass through. CAREFULLY use a razor blade/ utility knife to cut from one side to the center hole. Slip in wires and pop plug back in. Factory looking grommet.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 07-11-2002, 12:45 AM   #5
Hooter
My other Love
Hooter's Avatar
Fumes? what fumes? whos talking? whos truck am i sitting in?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-12-2002, 04:18 AM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
Also, if you ever dragrace, I know the track I race at will get you on those. They'd probably still let you run if that was the only infraction, but they don't like it much.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Thread Tools
Display Modes
