07-10-2002, 11:21 PM | #1 |
a/c acting up
was wondering why the ac on my 94 will sometimes work and other times not. 2 days ago on my way to work it just started blowing warm air. then on the way home that night after trying 3 or 4 times it came on. did the same thing today also but this morning it came back on after about 20 min. any ideas??
1972 K/20,4X4,454, dark olive 1937 General motors truck (big project) 2005 gmc envoy (wife's) 2003 2500hd ls, crewcab, 4x4, 360, hd 4spd automatic trans., Lee's summit, MO. S.E. of Kansas City,MO |
07-10-2002, 11:33 PM | #2 |
Compressor not engaging? Is the charge up to snuff? A low charge could keep the compressor from coming on.
07-10-2002, 11:42 PM | #3 |
when it works it's blowing very cold air. I'll have to check and make sure the compressor is kicking on in the morning.
07-11-2002, 12:03 AM | #4 |
A low charge can blow too cold. Put some gages on it and see what the high and low side read.
07-11-2002, 02:40 AM | #5 |
"See the U.S.A....."
The wire connector to he low pressure switch on the acuumulator gets loose all the time on those. I seen it countless times. the next time it stops blowing cold, wiggle this connector.If the compressor starts when you wiggle the connector replace it and the loww side switch.It just unscrews and you will not loose any freon (has a schrader valve).
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
07-11-2002, 08:32 PM | #6 |
not to get to far off the subject - but
what's a good price for a set of AC manifold gauges? |
Thread Tools | |
Display Modes | |
