Old 11-27-2005, 05:27 PM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Ball joint wear
Can anyone tell me how to tell if ball joints are worn.I think mine are fine but plan on putting new spindles on soon and want to be sure I don't put them on bad joints.I looked in FAQ's and didn't find any info on this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-27-2005, 05:31 PM   #2
FormerMember
Re: Ball joint wear
Jack the truck in the air. Lift the bottom of the tire outward and toward the top, while someone looks at the ball joint. If it deflects at all, it's bad.
Also a good check for wheel bearings.
FormerMember is offline   Reply With Quote
Old 11-27-2005, 11:43 PM   #3
powell72
powell72's Avatar
Re: Ball joint wear
When you jack it up, put the jack under the spring pocket on the control arm so the ball joint has no pressure on it. If not you will just find wheel bearing play if there is any.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-28-2005, 06:49 AM   #4
dyingdeadman
dyingdeadman's Avatar
Re: Ball joint wear
if i was replacing the spindles I would probely go ahead and replace the ball joints too. there not too pricey and you wont have to worry about em for another 20 years or so.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Thread Tools
Display Modes
