11-28-2005, 01:53 AM | #1 |
Need help with trailer light wiring
I am taking off a hitch from another truck, since this 3/4 ton will do alot better pulling now with front discs. Anyway, the couple of trailers I have use that 4 pin connector and they don't have trailer brakes.
How is the best way to hook this up correctly? I was thinking that I'd just crawl under and splice them into the white, green, yellow lines that run to my tail lights. Someone suggested not doing that though, because you have to use diodes or something to prevent the trailer lights from burning out. I'm confused... and our trucks are old enough they don't make plug and play kits like new vehicles. |
11-28-2005, 07:03 AM | #2 |
Re: Need help with trailer light wiring
Your splicing idea should work fine. The only thing you will have to add is a heavier-duty flasher. When you put the extra bulbs in the mix your trun signals will not blink properly.
Also, be sure that the connector is wired correctly. The side of the plug that has only one bullet exposed belongs on the truck, and that is the ground wire. This way when there is no trailer attached, the exposed wire on the truck side of the connection is not hot....no short/blown fuses. Yes I have seen it done backward, that's why I mentioned it. |
11-28-2005, 08:28 AM | #3 |
And by all means hook the truck side ground wire to a good ground on the truck.
All my buddys don't and just allow the ground to attempt to go through the trailer ball to the frame of the truck. Then they complain about flaky trailer wiring. One more thing. Here in Minnesota where you are driving in salt 5 months out of the year, those blue 3M splice deals corrode and lose contact after a winter or two. If you want to do it right the first time solder all your connections and seal them up right the first time.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-28-2005, 09:49 AM | #4 |
on my 71 when i rewired the brake lights where the plug is under the bed there was another plug pluged into it for my taoir lights the name one the side of the plug is hoppy lite mate #4110 u just unplug you harness under the bed plug this in and have a long enough wire to run to it and the talior and don't forget to plug you brake light harness back into the back of it i think its pretty cool
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 11-28-2005 at 09:51 AM. |
11-28-2005, 09:58 AM | #5 |
http://www.trailerwiring.com/ just enter what ever year and it will come up with what u need part number 41105
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 11-28-2005 at 10:04 AM. |
11-28-2005, 01:33 PM | #6 |
heres an ttt for u hope someone can asnwer better then me
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-28-2005, 08:15 PM | #7 |
its all about the +6 inches
As far as splicing... I would say screw the solder... it is good in a \n ideal envirnoment...but under the bumper is far from ideal. Do with the crimp on butt connectors that have heat shrink on them. They cost a bit, but they are top notch. (this is what GM has on there harness repair kits too)
But...with that said...screw that idea. Run down to NAPA and order P/N 755 1554, that'll get you the plug and play as you described, and no searching for the hoppy dealers or anything. |
11-28-2005, 09:00 PM | #8 |
I have two different connectors wired up on the truck right now. The new(to my truck) step bumper has a big 7 way round connecter set up for trailer brakes mounted on it, I just don't have the brake controller, gotta go back to the junkyard and get it. I also installed a 4 way flat connector, I just wrap the cable around the bumper bracket when I'm not using it. I would've just bought the adapter that plugs into the 7 way and converts it to 4, but I already had the wire harness. When I wired 'em up I used regular splice connectors, but I wrapped 'em in the 3M electrical tape that costs about 5 bucks a roll. When I hooked up the white ground wire I put a ring terminal on the end and used a small hole that was already drilled in the frame to mount it. I just got the grinder and cleaned the rust off before connecting it. Also, both connectors are spliced into the factory wire harness on my truck, and I never had a problem with bulbs blowing out.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
12-01-2005, 10:45 AM | #9 |
Well, I tried doing wiring this myself and had nothing but problems splicing into the right wires etc. This time of year it's really cold and not as easy or fun to work under the truck. I finally just broke down and took the part number to NAPA that Longhorn Man suggested.
WOW! That was almost too easy, I could have saved alot of time if I did that in the first place. I thought it would be more expensive than making my own kit, but it was only $6.00! Thank you Andy! Anyone wanting to add trailer wiring, GO THIS ROUTE! Works like a charm, it's cheap, and saves ALOT of time doing it yourself! |
12-01-2005, 04:00 PM | #10 |
wow...i had no idea it was only 6 bucks. Cool
Robert, in most parts of texas, you can splice all day long. Get to areas where it snows, and you start having problems. Road salt, and even worse now, brine, gets ionto the splice and kills the wires. The brine gets into everything, it'll get under the heads of rivits and start to corrode the melat... so it'll get through the tape with no problems. |
12-01-2005, 07:18 PM | #11 |
Yeah I was told that it's a bad idea to cut and splice the wires, especially if you use those scotchlock connectors.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 12-01-2005 at 07:20 PM. |
12-01-2005, 08:26 PM | #12 |
Project Junkie! Fishing Poor!!
M&H has just come out with a new trailer wiring plug. It is a lot better than the adapter that is on the market now. The one that is on the market now will not hold the plugs together, nor is it weathertight. The new M&H ones are. They also come with a lenth of wire to wire your trailer plug. These plugs haven't been releiced yet, but I will have some on the shelf next weak. The price is $29.95 for them, but after fighting with the adapter that is on the market now and wiretyeing the one I have now. They will be well worth the money. And yes!! USA made!! WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-01-2005, 11:37 PM | #13 |
Personally I prefer solder and heat shrink. The hoppy is quicker, but they can have connection issues after they have been installed awhile. I learned that the hard way.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
12-02-2005, 07:30 PM | #14 |
That is because they are not weather tight. The terminals carode from the weather and the terminals come loose under it's own weight. M&H's new kit will be completely weather tight and plug in just like your original taillight harnesses plug. They will even be housed in a rubber connector just like the originals. WES www.ClassicHeartbeat.com
Thread Tools | |
Display Modes | |
