07-11-2002, 01:06 PM | #1 |
SKINNY TIRES RULE!
Ball Joints
My upper driver's side ball joint is shot. I have most of the front end appart but I can't get the nut off the top of the ball joint. The problem is, the ball joint is spinning freely so I can't break the nut free. Does anyone have any ideas how to fix this.
Here's a quick illustration of my problem. I thought about grinding the nut off, but I don't have a grinder. I also thought about drilling into it but if it is hardened steel, that probably won't work either.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L Last edited by bouncytruck; 01-12-2006 at 05:06 PM. |
07-11-2002, 01:18 PM | #2 |
The face of my 69 c10
I would try a sawzall if you have one available it may be able to cut it I actually cut my front sway bar mounts off of the frame with my cordless Porter Cable sawzall. It was a hell of alot easier than trying to drill them out.
2002 Harley Davidson VRod 1972 2wd Blazer (Project) 1969 Chevy C10 (Driver) 2002 Chevy Trailblazer (Wifes) |
07-11-2002, 01:27 PM | #3 |
Firefighter
Try driving a pickle fork in there and using an impact wrench.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
07-11-2002, 01:30 PM | #4 |
SKINNY TIRES RULE!
I could probably rent one for a day. Do you think that a saws all would be better than a grinder?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
07-11-2002, 01:36 PM | #5 |
pickle fork !!!
07-11-2002, 01:36 PM | #6 |
If you tear off the boot, is there room enough to get a pair of skinny vise grips on the shaft?
What about popping the cap off the other end and getting to it that way? Grind a groove in the end of the threaded shaft (like a slot screw head) and try to hold it still that way. Good luck.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
07-11-2002, 01:42 PM | #7 |
Yeah that pickle fork idea is better one.
07-11-2002, 02:08 PM | #8 |
SKINNY TIRES RULE!
Tried the pickel fork and vice grips. Neither of them held it solid enough to get the nut off (pickel fork came a lot closer though). I'll have to check for the groove in the bottom, but I don't think I can get enough leverage there to hold it in place.
07-11-2002, 02:40 PM | #9 |
get a bigger hammer and/or a better pickel fork. The pickle fork "shoulder" should be tall enough to become "lodged" between the spindle and the ball joint as to "tighten up" the balljoint nut. Once the nut is tight and the ball joint can't spin, then try to back off the nut. If the ball joint begins to spin, hammer the pickle fork "deeper" to keep the nut tight as you unscrew it.
Get a good pickle fork, if you work on vehicles you need good pickle forks (I have several and use them all ) |
07-11-2002, 02:44 PM | #10 |
to add to above, use an impact(air or electric) if you can ( may need a long extention )
07-11-2002, 02:44 PM | #11 |
IF ALL ELSE FAILS .... DRAG OUT THE SMOKE WRENCH. IT'LL TAKE ANYTHING OFF.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
07-11-2002, 02:47 PM | #12 |
Firefighter
Or if at all possible try to "Tack" weld it, that might work also. But first try the pickle fork and an Impact wrench.
07-11-2002, 05:04 PM | #13 |
its all about the +6 inches
One time I had to put a bottle jack inbetween the upper and lower A arms...then drove a pickle fork in there, and jacked up the jack untill the arms were flexing a little.
Dangerouse...use it as a last resort...well, before the hot wrench anyways. |
07-11-2002, 05:15 PM | #14 |
SKINNY TIRES RULE!
It's a 4wd - no A arms. What is a "hot wrench"
07-11-2002, 05:18 PM | #15 |
Firefighter
Cutting Torch!!
07-11-2002, 05:26 PM | #16 |
SKINNY TIRES RULE!
Humm, don't have one of those or know anyone with one so I guess that's out of the question. I have a buddy with an angle grinder so I think I'll give that a try.
07-11-2002, 05:37 PM | #17 |
hmmm, I shoulda looked at who I was talkin to huh?
sorry, |
07-11-2002, 07:58 PM | #18 |
SKINNY TIRES RULE!
No problem longhornmail, the idea may come in handy in the future...
07-11-2002, 09:19 PM | #19 |
damn what luck i just had a look at my balljoints while i was changing out brake callipers and seen my upper ball joint on the drivers side is shot too.
1972 C/10 LWB 1972 K/5 Blazer |
07-11-2002, 09:29 PM | #20 |
Saving 1 truck at a time!
bouncytruck...have them all in the South end...Kent...if you want to drive down here. I will be in Olympia tomorrow but will be around the rest of the weekend.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
07-12-2002, 12:53 AM | #21 |
Had the same thing happen to my 4x4. I drove the ball joint back up into the hole as tight as I could. This provided enough friction to get the nut off. Liberal use of WD40 on the threads helped too. You can also try to just heat the nut with a small torch.
The more I learn about women, the more I love my truck. |
07-12-2002, 12:44 PM | #22 |
SKINNY TIRES RULE!
stllookn, thanks but the thing is 90% appart and sitting on jack stands right now. The rotors, hubs and axles are in the garage. I'm going to borrow a buddies angle grinder and see if I can do some damage with that.
07-12-2002, 12:56 PM | #23 |
CCRider
It's a castle nut, it should be quite easy to cut it with a BFH and a sharp chisel. If need be, cut both sides even with the slots for the cotter pin. I have cut grade 8 nuts this way with no problem.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
07-12-2002, 01:23 PM | #24 |
SKINNY TIRES RULE!
I figured that the nut would be too hard for a chisel. I'll give that a try before the grinder. Thanks!
07-12-2002, 01:42 PM | #25 |
I would cut the majority with either a grinder or plasma cutter. You probbly don't have a plasma cutter or know someone that has one. I'd cut most just about everything with a grinder, but leave some there so you don't knick up the axle then use a chisle to get the remaning off.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Thread Tools | |
Display Modes | |
