No No
Steering Column Problems (shifter)
I've about had enough with this steering column it's driving me
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
Re: Steering Column Problems (shifter)
Reverse and first are the hardest gears to get in . Are you sure that you are not feeling the gears grinding a little . It will travel through the linkage to the shifter handle and feel like the handle is grinding . Just a thought . Frank
Born and proudly residing in a Red State ! |
No No
No, the gears and the transmission are fine. It's kinda hard to see in the pics but the shifter part of the column in the cab rubs the key housing area. It's been wearing on it real good too, if you take your finger and rub it around the area in the pic it will cut it.
No No
Well I dug up my original column whats left of it. I replaced it a couple years back since the sections where the bearings sit were wasted. I pulled it apart to get an idea of whats going on. I still dont see why or how the shift collar is prevented from doing what its doing in the truck now but my orginal dident have this issue and this one recently developed the problem. I see a plastic bushing on the lower portion that prevents metal to metal contact but nothing on the top.
![]() I might just be getting the firebird back on the road sooner then I want since 3 speed columns are hard to come by. ![]()
I'm back with 2nd truck!
I've had a shifter on my 84 like that but never ran into that problem. My problem I was running into was the plastic tiny shaft would break and you couldn't get into a gear other than first. It was a safety feature in it to collapse during a wreck. Strange for sure.
Best thing you can do it change the shifter for a floor shifter.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#6 | |
No No
ureckmefixit2@cox.net
Might be the steering shaft from the steering box, pushing the shaft up the column from the cab settleing. Might try loosening the clamp or the column and pulling it up a little. Matt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
Thread Tools | |
Display Modes | |
