GMC Dreamer
Back up light on in drive
Just wonderin what I have to do to get this working correctly. When I'm drivin down the road now the back up lights are on in drive instead of reverse. Is this a problem in the column or is it somethin on the trans?
![]() Join Date: May 2005
Re: Back up light on in drive
It's probably your neutral safety switch. It's the horseshoe shaped device attached to the lower part of your steering column. Just loosen the two set screws, and slide it left or right to adjust the switch inside.
Pete. |
Thread Tools | |
Display Modes | |
